Jake the 312-8 72 #1 Posted August 6, 2023 I flipped a axel on a wheelhorse to lower it and i did it and its is just not right and i flipped spindles and bend them! Any body got any tips? Share this post Link to post Share on other sites
SylvanLakeWH 32,279 #2 Posted August 6, 2023 Any pictures? Share this post Link to post Share on other sites
Pullstart 71,160 #3 Posted August 6, 2023 2 hours ago, Jake the 312-8 said: any tips? 2 hours ago, Jake the 312-8 said: flipped a axel on a wheelhorse If you see the weight of the tractor is now supported by some fairly thin C clips, it would be wise to build some stronger type of holdfast. 1 Share this post Link to post Share on other sites
Jake the 312-8 72 #4 Posted August 10, 2023 Yeah here is some pics Share this post Link to post Share on other sites
Jake the 312-8 72 #6 Posted August 10, 2023 I just need to know about the spindles or if anybody has info Share this post Link to post Share on other sites
oliver2-44 11,712 #7 Posted August 10, 2023 Post some pictures of your spindles and steering linkage and tell us what’s not right Share this post Link to post Share on other sites
ineedanother 2,843 #8 Posted August 10, 2023 I would suspect that you'll need to drill and tap the spindles so you can thread something in from underneath that will support the weight. 1 Share this post Link to post Share on other sites
Jake the 312-8 72 #9 Posted August 18, 2023 Its cambered and its to low i just need to know how others do it. Thank you guys Share this post Link to post Share on other sites
