Wvtroutbum81 304 #1 Posted July 29, 2023 How do you set the adjustment on the governor arm, It either has too much throttle or not enough. thanks Share this post Link to post Share on other sites
pfrederi 18,970 #2 Posted July 29, 2023 Pages 6A 12-14 Give the needed adjustment Share this post Link to post Share on other sites
Wvtroutbum81 304 #3 Posted July 29, 2023 13 minutes ago, pfrederi said: Pages 6A 12-14 Give the needed adjustment Thank you! Share this post Link to post Share on other sites
peter lena 9,455 #4 Posted July 29, 2023 @Wvtroutbum81 regularly put a few drops of super lube on each side of that gov shaft ,along with a linkage touch up , every related movement point should move with ease . started doing that when i started also lubing my choke / throttle cables . pete Share this post Link to post Share on other sites
Wvtroutbum81 304 #5 Posted July 29, 2023 2 hours ago, peter lena said: @Wvtroutbum81 regularly put a few drops of super lube on each side of that gov shaft ,along with a linkage touch up , every related movement point should move with ease . started doing that when i started also lubing my choke / throttle cables . pete Thanks Pete, Shimmed with washers, lubed pivot points and repacked all the pto bearings with the green lucas👍 1 Share this post Link to post Share on other sites
peter lena 9,455 #6 Posted July 30, 2023 @Wvtroutbum81 thanks for the feedback ! watch out , you keep making gains like that and people will talk , BTW nice rainbow . been tying and fly fishing , many years , most of my fishing is pontoon kck boat . whats happening , lucas green grease , repacking bearings , lubing pivot points , washer shimmjng , what have I done ? pete 1 Share this post Link to post Share on other sites
