SmilingBob 11 #1 Posted July 29, 2023 (edited) Ordered a Champion H10C spark plug, Kohler K points and condenser set, air filter, and a spark plug wire kit from iSaveTractors.com for my 79 Wheel horse C141. The wire kit had coil terminal and boot are already installed the spark plug terminal and boot need to be installed after the cable is cut to length, it's 24 inch long. I pulled the existing spark plug wire with the intention of measuring it to make the new wire ,and set it aside till I got the proper crimper for the terminal. Well I set it aside so well that I can't seem to find it. Could someone please measure the length of their spark plug wire? Checked the resistance of the new wire at the 24 inch length and got a reading of 0 .3 ohms. SmilingBob Edited July 29, 2023 by SmilingBob Share this post Link to post Share on other sites
ebinmaine 75,752 #2 Posted July 29, 2023 Might wanna use your own engine as the gauge. If a PO has moved or changed the coil a stock length could come up short. Share this post Link to post Share on other sites
