peejo50 37 #1 Posted July 25, 2023 Just replaced the front tires on my 312-H. Got a set of Hi-Run 15x6.00-6 4-ply Turf II from Home Depot for about $50 delivered. They were a bear to get inflated even with a ratchet strap wrap. First and should be the only replacements ever needed in my lifetime. 7 Share this post Link to post Share on other sites
Pullstart 68,076 #2 Posted July 25, 2023 They look great! I like to use bead sealer or mounting lube or both. It definitely helps with the beading and inflation process! 1 Share this post Link to post Share on other sites
ebinmaine 74,473 #3 Posted July 25, 2023 2 hours ago, peejo50 said: They were a bear to get inflated That's why I started installing tubes in EVERY tire I change. 3 2 Share this post Link to post Share on other sites
Pullstart 68,076 #4 Posted July 25, 2023 That also takes care of the issue 1 Share this post Link to post Share on other sites
pfrederi 18,951 #5 Posted July 25, 2023 I have a Cheetah Bead seater. Didn't pay attention to the recommended pressure for the small front ties. Seated the bead but blew the tire and wheel halfway across the shop.... 1 5 1 Share this post Link to post Share on other sites
ebinmaine 74,473 #6 Posted July 25, 2023 6 minutes ago, pfrederi said: I have a Cheetah Bead seater. Didn't pay attention to the recommended pressure for the small front ties. Seated the bead but blew the tire and wheel halfway across the shop.... 😮🤯🤬 Share this post Link to post Share on other sites
lynnmor 8,074 #7 Posted July 25, 2023 I spread the beads apart with blocking for days so the beads hug the wheels when installed. 4 Share this post Link to post Share on other sites
Thor27 844 #8 Posted July 25, 2023 3 hours ago, pfrederi said: I have a Cheetah Bead seater. Didn't pay attention to the recommended pressure for the small front ties. Seated the bead but blew the tire and wheel halfway across the shop.... There is a recommended pressure? I thought fetching them was just part of the experience 🤔... 2 Share this post Link to post Share on other sites
