Richardmewen 4 #1 Posted July 17, 2023 16hp kohler no gas getting to the carb. New fuel pump,new carb,fuel lines,fuel filter. ??? Share this post Link to post Share on other sites
WHX?? 54,979 #2 Posted July 17, 2023 (edited) What kind of new fuel pump. Cheapy plastic one by chance? I've had them bad right out of the box. I've also had them run fine last a long time. 50/50 roll of the dice on them. Long shot but did you try and hand feed to get the pump primed. Edited July 17, 2023 by WHX?? Share this post Link to post Share on other sites
peter lena 9,764 #3 Posted July 18, 2023 @Richardmewen https://www.google.com/search?q=carbole+electric+fuel+pump%2C+loe+pressure&rlz=1C1CHBF_enUS866US866&oq=CARBOLE+&gs_lcrp=EgZjaHJvbWUqBggB have 2 of these in use on my horses , very quiet / reliable , no issues . also have fuel check valves on all my engines / carb set up .visible fuel holding in place to carb , use the low pressure model . wired into start / run . self monotoring , pete Share this post Link to post Share on other sites
ineedanother 1,872 #4 Posted July 18, 2023 Tank under the hood or the seat pan? Regardless, start at the source and trace it to the motor. Often times the petcock gets clogged right at the tank but follow it downstream from there until you find where it's stopping. Share this post Link to post Share on other sites
Richardmewen 4 #5 Posted July 18, 2023 Thank you for responding. New petcock and the tank was removed and cleaned out. Share this post Link to post Share on other sites
gt14rider 1,045 #6 Posted July 18, 2023 Have you checked gas cap vent. Share this post Link to post Share on other sites
Richardmewen 4 #7 Posted July 24, 2023 I have not checked the gas cap. Good idea I will try it Share this post Link to post Share on other sites
