Pogo 57 10 #1 Posted July 16, 2023 The coil on my 753 seems very hot after running with the hood off At idle amp gage is n the center At running speed it moves to the first line. Do I have a problem? Thanks. Share this post Link to post Share on other sites
ri702bill 11,149 #2 Posted July 16, 2023 4 hours ago, Pogo 57 said: Do I have a problem? Maybe - did you just change the coil?? You need the coil with the internal resistor - it is not an automotive coil. There are numerous articles here on the forum regarding this........... Bill 1 Share this post Link to post Share on other sites
Pogo 57 10 #3 Posted July 17, 2023 Thanks for the info. It looks to have been there for a long time. May have been changed sometime in the last 60 years Going to pull the trigger and putt a new one on. Good thing the wiring has been left intact after all these years. Share this post Link to post Share on other sites
squonk 45,380 #4 Posted July 17, 2023 You want a Napa IC14 or equivalent. Internally resisted coil. 2 Share this post Link to post Share on other sites
Rick3478 445 #5 Posted July 17, 2023 2 hours ago, squonk said: You want a Napa IC14 or equivalent. Internally resisted coil. or add an external resistor, but yeah use the right parts. 1 Share this post Link to post Share on other sites
