Banjo 0 #1 Posted February 10, 2008 Any thoughts on the fix for this one? TIA Share this post Link to post Share on other sites
TR_DIGGER 3 #2 Posted February 10, 2008 check the pin and set screw that hold the shifter in place... just a thought :thumbs: Share this post Link to post Share on other sites
pond195520032003 27 #3 Posted February 10, 2008 Yea what he said or it could be that the pi/ball bearing's is worn or the spring is weak in the transmission you have to split the case to replace them done it before, first time a few years ago and when the outer bearing flew out in landed in a pile of leaves took me 2 hours to find it :P Share this post Link to post Share on other sites
Rollerman 290 #4 Posted February 10, 2008 It only comes out of 1st? Thats a new one on me...I have seen 2nd & 3rd haveing that issue...I've even bought my share of parts tractors with the accessory bungee strap. TR Digger's is good advice too...always a good idea to doble check the set screw at the base of the shifter....no (54) & (55) in the diagram. THe spring Greg Mentioned is (15) I would say another problem might be the shift rails (11 & (12) have become worn too not letteing the detent ball & spring do there job. Snug the set screw first & see if that helps. :thumbs: Share this post Link to post Share on other sites
Banjo 0 #5 Posted May 4, 2008 I originally posted this in the winter and the info was incorrect. It is actually popping out of 3rd, and yes, it has the bungie cord option now too LOL. Share this post Link to post Share on other sites
Banjo 0 #6 Posted May 4, 2008 check the pin and set screw that hold the shifter in place... just a thought I can see those items in tickster's diagram but can I get to them without pulling the fenders or anything? Is the square cast they go into just below the shifter boot so I don't have to take the tranny apart? Share this post Link to post Share on other sites
Banjo 0 #7 Posted May 4, 2008 Yea what he said or it could be that the pi/ball bearing's is worn or the spring is weak in the transmission you have to split the case to replace them done it before, first time a few years ago and when the outer bearing flew out in landed in a pile of leaves took me 2 hours to find it I bet it was not funny at the time but..LOL! Share this post Link to post Share on other sites
