Banjo
1972 Commando 800 Pops out of 1st Gear
Banjo
Any thoughts on the fix for this one? :thumbs:
TIA
TR_DIGGER
check the pin and set screw that hold the shifter in place... just a thought :thumbs:
pond195520032003
Yea what he said :P or it could be that the pi/ball bearing's is worn or the spring is weak in the transmission :D you have to split the case to replace them :thumbs: done it before, first time a few years ago and when the outer bearing flew out in landed in a pile of leaves :D took me 2 hours to find it :thumbs: :P
Rollerman
It only comes out of 1st?
Thats a new one on me...I have seen 2nd & 3rd haveing that issue...I've even bought my share of parts tractors with the accessory bungee strap.
TR Digger's is good advice too...always a good idea to doble check the set screw at the base of the shifter....no (54) & (55) in the diagram.
THe spring Greg Mentioned is (15)
I would say another problem might be the shift rails (11 & (12) have become worn too not letteing the detent ball & spring do there job.
Snug the set screw first & see if that helps. :thumbs:
Banjo
I originally posted this in the winter and the info was incorrect. It is actually popping out of 3rd, and yes, it has the bungie cord option now too LOL.
Banjo
check the pin and set screw that hold the shifter in place... just a thought :whistle:
I can see those items in tickster's diagram but can I get to them without pulling the fenders or anything?
Is the square cast they go into just below the shifter boot so I don't have to take the tranny apart?
Banjo
Yea what he said :D or it could be that the pi/ball bearing's is worn or the spring is weak in the transmission :dunno: you have to split the case to replace them :WRS: done it before, first time a few years ago and when the outer bearing flew out in landed in a pile of leaves :D took me 2 hours to find it :whistle::D
I bet it was not funny at the time but..LOL!
