RED-Z06 2,718 #1 Posted July 4, 2023 The lights on my 416 are going bad, the contacts are going and im looking into replacement options that look the same but more importantly fit the same. Share this post Link to post Share on other sites
peter lena 9,797 #2 Posted July 4, 2023 @RED-Z06 walmart has them , same size , led , nice and bright , have them on my 3 horses , zero issues about $ 6-7 each , also available in orange . pete Share this post Link to post Share on other sites
RED-Z06 2,718 #3 Posted July 5, 2023 4 hours ago, peter lena said: @RED-Z06 walmart has them , same size , led , nice and bright , have them on my 3 horses , zero issues about $ 6-7 each , also available in orange . pete Went and looked at them, i liked them but I want to run my own bulbs, i dont like hardwired leds. Found these on ebay for about 12ea. Share this post Link to post Share on other sites
peter lena 9,797 #4 Posted July 5, 2023 @RED-Z06 that will work , never had an issue with the glowing LED lights , might get a better price on amazon .easy swap ,pete Share this post Link to post Share on other sites
RED-Z06 2,718 #5 Posted July 5, 2023 2 hours ago, peter lena said: @RED-Z06 that will work , never had an issue with the glowing LED lights , might get a better price on amazon .easy swap ,pete They usually work well but if one diode fails you cant fix it, then you have to find another matching replacement. I mainly ran into it with my trailer lights, they had them built in and it was fine intil half the brake light ring on one side failed and i couldnt find another single light so i had to get a while kit 2 1 Share this post Link to post Share on other sites
bds1984 1,506 #6 Posted July 5, 2023 Any place that sells trailer lighting will have what you need. I drive I94 daily and pass by many gas stations that sell them. Share this post Link to post Share on other sites
RED-Z06 2,718 #7 Posted July 7, 2023 (edited) Got them on. Used the factory holes, put in led bulbs, they frame ground like oem, connected 1 wire each and off it went..both sides took about 5mins to mount including drilling the stock rivets. Edited July 7, 2023 by RED-Z06 3 Share this post Link to post Share on other sites
peter lena 9,797 #8 Posted July 8, 2023 @RED-Z06 like the led,s do a lot of roadside plowing and like the road view , never had an issue , that horse paint , could use an areosol lubricant spray down , let it sit / soak a day , rub it down till dry with a soft clean cloth , do it again , second rubdown will probably bring out the dull paint . I use a 6" palm buffer with any cleaner wax , makes it quick easy , having done my horses , the paint just is very solid red , rub them down with a lubricated cloth. regularly , started with a dull finish . they all look clean , all workers , pete Share this post Link to post Share on other sites
peter lena 9,797 #9 Posted July 8, 2023 @RED-Z06 , faded to clean / shinny , pete Share this post Link to post Share on other sites
RED-Z06 2,718 #10 Posted July 8, 2023 41 minutes ago, peter lena said: @RED-Z06 like the led,s do a lot of roadside plowing and like the road view , never had an issue , that horse paint , could use an areosol lubricant spray down , let it sit / soak a day , rub it down till dry with a soft clean cloth , do it again , second rubdown will probably bring out the dull paint . I use a 6" palm buffer with any cleaner wax , makes it quick easy , having done my horses , the paint just is very solid red , rub them down with a lubricated cloth. regularly , started with a dull finish . they all look clean , all workers , pete Its been clearcoated. .it bought time but its bad now, whole tractor needs a strip, respray and decals. 1 Share this post Link to post Share on other sites
