rjg854 12,636 #176 Posted July 30, 2024 1 hour ago, JPWH said: Just waiting for the ok from my oncologist to start fabrication. Not sure why he would have any say in when you start your mental therapy sessions. This should aid in your recovery. 2 Share this post Link to post Share on other sites
JPWH 6,542 #177 Posted July 30, 2024 36 minutes ago, rjg854 said: Not sure why he would have any say in when you start your mental therapy sessions. This should aid in your recovery. Because of comprised immunity. Mental therapy has been building it in my head and finding things I haven't thought about as well as sourcing parts. 1 Share this post Link to post Share on other sites
JPWH 6,542 #178 Posted July 30, 2024 50 minutes ago, wallfish said: Jay, It's great to see you persevering and getting right back on this build. That bed does have a good look to it Thanks John. As long as I'm topside I'm going to give it my all. I will be modifying the bed a little as I repair it. But keep the same look. I may add another side pocket to each side. 4 Share this post Link to post Share on other sites
JPWH 6,542 #179 Posted July 30, 2024 (edited) 1 hour ago, wallfish said: Edited July 31, 2024 by JPWH Double post Share this post Link to post Share on other sites
953 nut 63,075 #180 Posted July 31, 2024 On 7/29/2024 at 5:39 PM, JPWH said: tailgate has Cushman embossed on it. That needs to be corrected for surer, Can't have a super cool custom Wheel Horse one of a kind Wheel Horse running around with Cushman hangn' from its tail. 3 Share this post Link to post Share on other sites
JPWH 6,542 #181 Posted July 31, 2024 42 minutes ago, 953 nut said: That needs to be corrected for surer, Can't have a super cool custom Wheel Horse one of a kind Wheel Horse running around with Cushman hangn' from its tail. I won't be using the tailgate. Maybe hang it up on my shop. 1 1 Share this post Link to post Share on other sites
Handy Don 15,228 #182 Posted July 31, 2024 3 hours ago, JPWH said: Thanks John. As long as I'm topside I'm going to give it my all. Inspiring attitude. Thanks! 1 Share this post Link to post Share on other sites
JPWH 6,542 #183 Posted July 31, 2024 Got released for normal activities today. I have 3 weeks before surgery to make some progress. Weekend plans are shop time! 1 5 3 Share this post Link to post Share on other sites
JPWH 6,542 #184 Posted August 4, 2024 I spent some time cleaning up my shop from months of "lay down n go" so I could have room to work on the dump truck build. I did a rough layout and next step is seating area. That will determine overall length and wheel base. 7 4 Share this post Link to post Share on other sites
JPWH 6,542 #185 Posted August 4, 2024 Floorboard and seat frame mocked up. Also the position of the motor and front axle mocked up. Nothing is welded in place just tacked or clamped. 8 1 Share this post Link to post Share on other sites
Handy Don 15,228 #186 Posted August 4, 2024 Great progress! Gonna need a loooonnnnng drive belt! 2 1 Share this post Link to post Share on other sites
953 nut 63,075 #187 Posted August 4, 2024 That will fit in well with the LOOOOOONG Truck thread going on here. Being that long it will need a LOT of room to turn it. Have you considered moving the front axle back some and the transaxle forward about 30 inches and running tandem rear axles? Would help out with maneuverability and look SOOOO KOOOOOOL! 5 Share this post Link to post Share on other sites
JPWH 6,542 #188 Posted August 5, 2024 I have the front axle positioned for maximum turning radius but the rear end could probably be moved forward. I haven't considered tandem. 1 Share this post Link to post Share on other sites
wallfish 18,791 #189 Posted August 5, 2024 Wheel base is probably the reason why every time I go to build another truck it turns into something else. I prefer short and maneuverable because I don't live on a farm. Akermann steering angles for the steering is important to gain the most turning radius and keep the front wheels on track. Wheel base length is going to determine the radius so the shorter it is the tighter the radius can be. https://en.wikipedia.org/wiki/Ackermann_steering_geometry 3 1 Share this post Link to post Share on other sites
JPWH 6,542 #190 Posted August 5, 2024 (edited) I don't have to have the rear axle under the bed. I could easily move it forward 30 inches. I don't have any real tight areas of my yard that I would need the dump truck for so turning radius would not be a problem. I have 2 1/2 acres to turn around if I need to. Edited August 5, 2024 by JPWH 3 Share this post Link to post Share on other sites
JPWH 6,542 #191 Posted August 5, 2024 6 hours ago, Handy Don said: Great progress! Gonna need a loooonnnnng drive belt! Not one long belt. 3 shorter belts and 2 jack shafts. 4 Share this post Link to post Share on other sites
953 nut 63,075 #192 Posted August 5, 2024 8 hours ago, JPWH said: I haven't considered tandem The second rear axle could be two 1 1/8" shafts supported by four pillow blocks. The assembly would probably want to be mounted on a pair of spring loaded swing arms to allow for uneven terrain reducing the potential for the drive wheels being lifted off the ground. Just a thought, don't want to complicate your build too much. 2 2 Share this post Link to post Share on other sites
Ed Kennell 43,804 #193 Posted August 5, 2024 8 hours ago, JPWH said: I could easily move it forward 30 inches. Moving the rear forward and shortening the frame could make it easier to tip the bed. 2 Share this post Link to post Share on other sites
JPWH 6,542 #194 Posted August 6, 2024 (edited) I did some more lay out today and I think I have the wheel base down to about 74" and a steering angle of about 40° - 45°. According to the turning radius calculator that should give me about a 6' - 6 1/2' turning radius. I think that is pretty short for a two seater dump bed and keep the dump truck look I am after. I will have to make a couple design changes but had ran short on a couple pieces of metal and needed to visit the metal shop anyway. Edited August 6, 2024 by JPWH 3 Share this post Link to post Share on other sites
wallfish 18,791 #195 Posted August 6, 2024 How big are your feet? You must be related to that French pole vaulter in some way and need the extra space in a couple of places! LOL https://www.dailydot.com/memes/french-pole-vaulter-bulge-memes/ Maybe possible to shorten that space a little? Just and a couple of jokes! 2 3 Share this post Link to post Share on other sites
JPWH 6,542 #196 Posted August 6, 2024 @wallfishThat was the main part of the re-design. Lol I gained almost 12" with that change. 3 Share this post Link to post Share on other sites
JPWH 6,542 #197 Posted August 7, 2024 I think I have found the final design. Now to start building it. I decided not to cut up any more metal mocking it up and just improvise, looks crude but it works. Final wheel base is about 66". 6 Share this post Link to post Share on other sites
953 nut 63,075 #198 Posted August 7, 2024 30 minutes ago, JPWH said: I have found the final design. Like the front axle placement. However, Won't those two short step ladders look a bit out of place. Wheels would work much better! 4 Share this post Link to post Share on other sites
ebinmaine 75,781 #199 Posted August 7, 2024 27 minutes ago, 953 nut said: Like the front axle placement. However, Won't those two short step ladders look a bit out of place. Wheels would work much better! I was wondering about steering without front wheels too. 2 Share this post Link to post Share on other sites
8ntruck 8,348 #200 Posted August 7, 2024 I like the set back front axle - looks proper on a dump truck. 1 Share this post Link to post Share on other sites
