Searcher60 209 #1 Posted June 29, 2023 1987 Wheel Horse, anybody found any products to make a faded WH steering wheel look like new? Mine is the black vinyl like steering wheel. Thanks! Share this post Link to post Share on other sites
ri702bill 13,271 #2 Posted June 29, 2023 (edited) I have had good success on shift knobs using Duplicolor Interior Panel and Carpet black spray dye. Has held up just fine on those for over 3 years. Easy prep, very thin - flows well. Takes about 3 to 4 coats. Does NOT fill imperfections when dry. Best done with the steering wheel removed from the tractor - not absolutely necessary, but easier to do a good job on it... Bill Edited June 29, 2023 by ri702bill Share this post Link to post Share on other sites
oliver2-44 11,791 #3 Posted June 29, 2023 I have used this on steering wheels and shifter knobs with good success. https://www.amazon.com/VHT-SP942-Vinyl-Black-Satin/dp/B000CPIN9S If its not to faded/deteriorated I have used this polishing compound with round and cone shaped buffing wheels in a drill. https://www.amazon.com/Swpeet-Polishing-Compounds-Flannelette-Mushroom/dp/B07TXG5QFR/ref=sr_1_1_sspa?crid=12OIKNIZM9L8N&keywords=buffing+wheel+cone+shaped&qid=1688052165&sprefix=buffing+wheel+cone+sshaped%2Caps%2C112&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1 https://www.amazon.com/Drixet-Jewelers-Polishing-Buffing-Compound/dp/B074HTV68F/ref=sr_1_1?keywords=white+rouge&qid=1688052039&sr=8-1 It it has any cracks you can clean the out with a thin cutoff wheel in a dremel. Then i use JB Weld with black spray paint mixed into it (to turn it black) I tape either side of the crack with blue painters tape, then work the epoxy into the crack. After its dry then use a file and sandpaper to work it to shape. 1 Share this post Link to post Share on other sites
Searcher60 209 #4 Posted June 29, 2023 24 minutes ago, oliver2-44 said: I have used this on steering wheels and shifter knobs with good success. https://www.amazon.com/VHT-SP942-Vinyl-Black-Satin/dp/B000CPIN9S If its not to faded/deteriorated I have used this polishing compound with round and cone shaped buffing wheels in a drill. https://www.amazon.com/Swpeet-Polishing-Compounds-Flannelette-Mushroom/dp/B07TXG5QFR/ref=sr_1_1_sspa?crid=12OIKNIZM9L8N&keywords=buffing+wheel+cone+shaped&qid=1688052165&sprefix=buffing+wheel+cone+sshaped%2Caps%2C112&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1 https://www.amazon.com/Drixet-Jewelers-Polishing-Buffing-Compound/dp/B074HTV68F/ref=sr_1_1?keywords=white+rouge&qid=1688052039&sr=8-1 It it has any cracks you can clean the out with a thin cutoff wheel in a dremel. Then i use JB Weld with black spray paint mixed into it (to turn it black) I tape either side of the crack with blue painters tape, then work the epoxy into the crack. After its dry then use a file and sandpaper to work it to shape. There is zero damage, the black and clear are faded. Actually, just clear would likely make it look fantastic. Share this post Link to post Share on other sites
ri702bill 13,271 #5 Posted June 29, 2023 6 hours ago, Searcher60 said: There is zero damage, the black and clear are faded. Actually, just clear would likely make it look fantastic. Hmmm... 20 years old , my 3 cents - do the black, then clear.............................. Share this post Link to post Share on other sites
