tallen4392 71 #1 Posted June 18, 2023 What do you guys use for blades on your decks to cut grass and chop the leaves in the fall i like to leave the leaves on the ground so chopping them up is a plus for me .. Thanks Share this post Link to post Share on other sites
moe1965 774 #2 Posted June 18, 2023 You could block off the discharge shute with a piece of wood so the leaves and grass could be chopped up some more . Using a mulching blade would help if there is a set that they make for your deck. Share this post Link to post Share on other sites
