jtrosp1980 89 #1 Posted June 14, 2023 The 69 raider 10 deck was 1421 the 67 1057 was RL-426 they look the same and have the same hook ups would it work Share this post Link to post Share on other sites
Pullstart 68,216 #2 Posted June 14, 2023 They both have the mid mount mule drive? I would think they would be plug and play. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,752 #3 Posted June 14, 2023 The model number format changed so the RL-426 and 5-1421 may be identical. Would need to compare ipl's to see. Mower DNA 1966-1967 model RL-426 replaced by 1968 model 5-1421 1969 model 5-1422 1970 model 5-1423 1971 model 5-1000 1971-1972 model 5-1001 1973-1974 model 5-1010 1975 model 5-1011 1975 model 5-1012 1976 model 65-42MS01 - Online Toro parts illustration is the 48" SD deck 1976 model 65-42MS02 - Online Toro parts illustration is the 48" SD deck 1977 model 75-42MS01 - These 42" side discharge decks all use blades with 5/8" x 3/4" double-D center hole unless the spindles have been upgraded (Do not have operator manual) -------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,752 #5 Posted June 14, 2023 5 hours ago, jtrosp1980 said: What is IPL Illustrated parts list. PL is a parts list with no illustrations and we do have a few. 1 Share this post Link to post Share on other sites
jtrosp1980 89 #6 Posted June 14, 2023 I don't mean to sound uneducated, but I found both units in the chart. Both have a 42" side discharge deck. After that I am lost. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,752 #7 Posted June 15, 2023 Here are 5 files on the RL-426 with one being the OM (operator manual and ipl. https://www.wheelhorseforum.com/search/?q=rl-426&quick=1&type=downloads_file This is what we have for the 5-1421. Some of it may be a repeat https://www.wheelhorseforum.com/search/?&q=5-1421&type=downloads_file&search_and_or=or&sortby=relevancy Keep the questions coming. 1 Share this post Link to post Share on other sites
jtrosp1980 89 #8 Posted June 15, 2023 Ok I think I understand here is my question I'm changing the motor out it had a techy puting a Kohler on so I will need the serial number from it not the body correct Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,752 #9 Posted June 15, 2023 You want paper work for the Kohler? Post the numbers off the ID plate Kxxx plus spec number. The serial not necessary but will date the year of manufacture. Post the numbers off the Tecumseh also so we can determine what else is needed to make the change. Model number and serial off the tractor will also help. 1 Share this post Link to post Share on other sites
jtrosp1980 89 #10 Posted June 15, 2023 The techy was a Hh100 I will get the Kohler when I get home in month Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,752 #11 Posted June 15, 2023 You may have noticed Toro does not recognize the 1057 model number but do recognize the 1257. These models shared a manual. Some how in the past I figured out what engine the 1057 originally used - Kohler K241S-46333d so the HH100 is not original. 1 Share this post Link to post Share on other sites
jtrosp1980 89 #12 Posted June 19, 2023 Hh100 was on the raider 10 Share this post Link to post Share on other sites
