Jake the 312-8 72 #1 Posted June 13, 2023 My 520 gets power with the key on but it will not turn it over when in crank position the battery is good and stuff but it will run when solenoid is jump! Any clue whats goin on? Fuses are good also Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,388 #2 Posted June 13, 2023 Download this file.. There is a diagram there for the starter circuit. 2 Share this post Link to post Share on other sites
Ed Kennell 41,316 #3 Posted June 13, 2023 The PTO safety switches is the first place I would look. 1 Share this post Link to post Share on other sites
lynnmor 7,703 #4 Posted June 13, 2023 Check the seat switch. 1 Share this post Link to post Share on other sites
oliver2-44 10,567 #5 Posted June 13, 2023 11 hours ago, Jake the 312-8 said: but it will run when solenoid is jump! I'm guessing you jumping the battery side of the solenoid To test the solenoid, jump 12v from the battery to the small terminal on the solenoid. If yu have a vvolt meter check that your getting 12v to the small terminal from the key switch when in the crank position. Share this post Link to post Share on other sites
Jake the 312-8 72 #6 Posted June 13, 2023 Ok thank you guys! Share this post Link to post Share on other sites
