Brockport Bill 2,553 #1 Posted June 12, 2023 not sure what forum on RSq to post this question -- but can anyone identify what models WH tractors this OEM seat pan goes to? Note the 4 hole pattern on the front bottom lip as well as the limited number of bolt holes on the top area? Otherwise, it apprears to be same size and shape as most other seat pan fenders??? Thanks !! 1 Share this post Link to post Share on other sites
ri702bill 13,399 #2 Posted June 12, 2023 No clue, but it is purdy !! 2 Share this post Link to post Share on other sites
kpinnc 19,109 #3 Posted June 12, 2023 Looks like a vertical shaft machine. All "Classic" horizontals had a gap in the center to mate up with the center/ lower console. 5 Share this post Link to post Share on other sites
Brockport Bill 2,553 #4 Posted June 12, 2023 11 minutes ago, kpinnc said: Looks like a vertical shaft machine. All "Classic" horizontals had a gap in the center to mate up with the center/ lower console. thanks for observaton and insight -- i had a 257h and it has the same "cut out" opening in the front as the "classic" seat pan you note and show in your photo --- however, it had a "plate" added to cover that seat pan fender "cut out" with a slot for the tranny release lever to come through to be operated - i will check the original parts diagrams for the other 200 series to see their design - thanks Share this post Link to post Share on other sites
Brockport Bill 2,553 #5 Posted June 12, 2023 found the diagrams on partstree.com - the seat fender pan is for all 260 series, plus 270 - thanks for helping. 3 Share this post Link to post Share on other sites
