Dreamcatcher 102 #1 Posted June 12, 2023 Does anyone have experience upgrading the non adjustable seat on a 310 with something like this? Amazon.com: LAWN & GARDEN TRACTOR SEAT W/SLIDE TRACK : Patio, Lawn & Garden Share this post Link to post Share on other sites
ri702bill 12,512 #2 Posted June 12, 2023 I do not, but looking at the reviews, it does not have a provision for a seat switch.... Share this post Link to post Share on other sites
Dreamcatcher 102 #3 Posted June 12, 2023 Thank you. I guess I need to take a closer look at my seat to see how the switch works. 1 Share this post Link to post Share on other sites
peter lena 9,952 #4 Posted June 12, 2023 @Dreamcatcher on the horse I recently sold , the seat / frame / base set up was very wrong , the end of it was actually sitting on the top of the fender ! have seats similar to that , but not exact match . the lower you go on the seat base mount to fender , gives you more steering wheel clearance on legs , if you carefully look at a better mount point , its only amatter of drilling some holes . just kept making small gains , had some preforated steel angle , as my test gain point . that i did cut and fit for a much better set set up . experimenting is a regular thing for me , its very east to paint something red , you would never know . pete 2 Share this post Link to post Share on other sites
Lee1977 7,710 #5 Posted June 12, 2023 (edited) The seat switch is mounted on the fender, there is a spring loaded pin in the swing up metal bracket where the seat mounts. It might work if you renove the seat springs. Edited June 12, 2023 by Lee1977 1 Share this post Link to post Share on other sites
clueless 3,427 #6 Posted June 12, 2023 Bolt pattern not a direct fit Share this post Link to post Share on other sites
kpinnc 18,756 #7 Posted June 12, 2023 Depending on your fabrication skills, anything can be made to work. Direct bolt on? Probably not. Share this post Link to post Share on other sites
squonk 47,423 #8 Posted June 12, 2023 (edited) I have this adjustable seat on my C-160 mounted on u springs. Very comfortable and I think I had to drill 2 holes. Edited June 12, 2023 by squonk 1 Share this post Link to post Share on other sites
Dreamcatcher 102 #9 Posted June 13, 2023 5 hours ago, squonk said: I have this adjustable seat on my C-160 mounted on u springs. Very comfortable and I think I had to drill 2 holes. That sounds great! Do you recal where you purchased it? Share this post Link to post Share on other sites
squonk 47,423 #10 Posted June 13, 2023 9 hours ago, Dreamcatcher said: That sounds great! Do you recal where you purchased it? I got mine at Surplus Center Share this post Link to post Share on other sites
