chev0545 236 #1 Posted June 11, 2023 mowing along motor just shut off any ideas Share this post Link to post Share on other sites
lynnmor 8,257 #2 Posted June 12, 2023 3 hours ago, chev0545 said: mowing along motor just shut off any ideas Will it start after it cools off? Share this post Link to post Share on other sites
8ntruck 8,334 #3 Posted June 12, 2023 (edited) Still got gas in the tank? Spark plug wires still on the plugs and coil? Any blown fuses? Did it stop like it was shut off and the engine coasted to a stop, or did the engine all of a sudden go to zero rpm? Possible broken wire or plug in the electrical system. Edited June 12, 2023 by 8ntruck 1 Share this post Link to post Share on other sites
chev0545 236 #4 Posted June 12, 2023 9 hours ago, lynnmor said: Will it start after it cools off? no Share this post Link to post Share on other sites
lynnmor 8,257 #5 Posted June 12, 2023 29 minutes ago, chev0545 said: no Then the most likely culprit is the white 9 pin connector near the battery. Does the starter operate normally? Did you check for spark? Tell us more about the tractor and what you have tried. Share this post Link to post Share on other sites
lynnmor 8,257 #7 Posted June 12, 2023 49 minutes ago, Joe Shmo said: Got oil? A 520 doesn’t have a low oil shutoff but it does have a low oil pressure light. 1 Share this post Link to post Share on other sites
