Countdown To Christmas!
jnelkie
3 point
jnelkie
does any one know if a 3 point assembly off a gt 14 will fit on a d 160
Rollerman
The lower arms may fit...may???, but everything else would be different.
refracman
Yup, Rollerman is correct, the only thing that will swap is the lower arms. The upper lift arms arm different and the links that go from the upper to lower are different. The Ds also need separate lift cylinder to control 3pt and bracket for the 3rd link.
