mattg 2 #1 Posted June 4, 2023 hello, I have power with a test light on both sides of the coil but no spark. does this mean the coil is bad? What should the ohms read on the coil? thank you! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,843 #2 Posted June 4, 2023 With battery ignition that indicates the points are not closing or the points are not making an electrical connection when closed. When the points are closed the coil (-) should be 0 volts. 1 Share this post Link to post Share on other sites
