vjerry 5 #1 Posted June 2, 2023 I've owned a Raider 8 for 30 years and now I want to get the deck back working. The only thing it needs is a spindle belt but I am having trouble finding the correct size???? Also if anyone knows the pattern that the belt should be installed in, it would be helpful to know. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,017 #2 Posted June 2, 2023 Welcome to Red Square One of these? 2 Share this post Link to post Share on other sites
8ntruck 8,632 #3 Posted June 2, 2023 to the forum. Is there an ID tag somewhere on the deck? A model number and serial number would help. Failing that, could you post a picture of the deck? There are folks here on the forum that will be able to identify the deck and point you towards the proper belt. Share this post Link to post Share on other sites
c-series don 11,510 #5 Posted June 6, 2023 Looks like you’re missing the idler pulley and spring as well? Share this post Link to post Share on other sites
vjerry 5 #6 Posted June 6, 2023 I have both, they were removed for cleaning and the idler is being replaced with new. Still hoping someone can tell me the model number of the deck since I am missing the belt???? 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,017 #7 Posted June 6, 2023 Is the deck a 36" width of cut side discharge? 1 Share this post Link to post Share on other sites
vjerry 5 #8 Posted June 9, 2023 Yes,that is correct 1 Share this post Link to post Share on other sites
vjerry 5 #9 Posted June 21, 2023 Anybody???? Still needing the fan belt size for the side discharge deck Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,017 #10 Posted June 22, 2023 Belts are on this page. 1 Share this post Link to post Share on other sites
peter lena 9,782 #11 Posted June 22, 2023 @vjerry hope you plan on going thru that deck , in additition to having help and direction to get that back correctly , would also re grease every bearing involved , original grease fails due to heat / stress, a 550 + temp and polyurea lucas grease will make it a quiet reliable runner . green grease / marine grease . also re grease the new idler pulley , and related pto drive bearings . deck sets ups are a collective lead sled dragging drive , everything you do to make it move easily will pay off , in quiet running . good luck with it , pete 1 Share this post Link to post Share on other sites
vjerry 5 #12 Posted June 23, 2023 Finally found the belt size. Unfortunately the deck does not have grease fittings on any of the spindles. Share this post Link to post Share on other sites
Marv 994 #13 Posted June 23, 2023 (edited) The spindle bearings are referred to as "water pump" bearings, part # 103119. Usually last a long time if you do not get "string" wrapped around the bottom of the shaft which ruins the seal. Marv PS: I have a new set of blades that fit that mower. Edited June 23, 2023 by Marv Share this post Link to post Share on other sites
vjerry 5 #14 Posted July 1, 2023 How much for the blades? Share this post Link to post Share on other sites
vjerry 5 #15 Posted July 14, 2023 (edited) Engine run like new because it was completely rebuilt, sheet metal and deck are in very good condition with only surface rust. Has new belts & tires Trying to decide if I want to sell it and buy a larger one? Edited July 14, 2023 by vjerry Share this post Link to post Share on other sites
