Bow_Extreme 583 #26 Posted August 2, 2023 (edited) Well, it appears I have a bad valve or seat. Going to unfortunately take a loss for now and swap this engine out with another, nearly new engine, I have sitting on the shelf. Not what I wanted or needed. I feel somewhat defeated on this. . Oh well, can’t win them all. I’ll eventually fix this engine but that will have to come to another day. Edited August 2, 2023 by Bow_Extreme 1 3 Share this post Link to post Share on other sites
lynnmor 8,915 #27 Posted August 2, 2023 6 hours ago, Bow_Extreme said: Well, it appears I have a bad valve or seat. Going to unfortunately take a loss for now and swap this engine out with another, nearly new engine, I have sitting on the shelf. Not what I wanted or needed. I feel somewhat defeated on this. . Oh well, can’t win them all. I’ll eventually fix this engine but that will have to come to another day. Did you pull the head to be sure what is going on? 1 Share this post Link to post Share on other sites
Bow_Extreme 583 #28 Posted August 2, 2023 3 hours ago, lynnmor said: Did you pull the head to be sure what is going on? Heads were pulled before I started this. I decarboned, made very minor valve clearance adjustments, and installed new head gaskets. Torqued bolts to spec. 2 Share this post Link to post Share on other sites
lynnmor 8,915 #29 Posted August 2, 2023 1 hour ago, Bow_Extreme said: Heads were pulled before I started this. I decarboned, made very minor valve clearance adjustments, and installed new head gaskets. Torqued bolts to spec. Since it took "very minor valve clearance adjustments" what leads you to believe there is a valve problem? What were the compression readings? 1 Share this post Link to post Share on other sites
Bow_Extreme 583 #30 Posted August 3, 2023 13 hours ago, lynnmor said: Since it took "very minor valve clearance adjustments" what leads you to believe there is a valve problem? What were the compression readings? Compression Check: 75 Front / 85 Rear Not good! 1 Share this post Link to post Share on other sites
Bill D 2,998 #31 Posted August 3, 2023 1 hour ago, Bow_Extreme said: Compression Check: 75 Front / 85 Rear Not good! I assume the throttle was wide open and the choke off when you took the compression readings. I had the throttle at idle one time when I ran a compression check on a KT-17. Numbers were way lower than with the throttle wide open. My apologies if the question seems insulting, but I've done it myself and know what happens when you do. Bill 1 Share this post Link to post Share on other sites
lynnmor 8,915 #32 Posted August 3, 2023 Your compression is at the low limit, I would would service the valves. Typically the throttle position doesn’t matter, on small governed engines, since the governor opens the throttle plate till the engine reaches at least idle speed. 1 Share this post Link to post Share on other sites
Bow_Extreme 583 #33 Posted August 18, 2023 (edited) Well, a second engine and we have progress. IMG_0041.mov Edited August 18, 2023 by Bow_Extreme 1 4 Share this post Link to post Share on other sites
Bow_Extreme 583 #34 Posted August 18, 2023 (edited) Well, a second engine and we have progress. Edited August 18, 2023 by Bow_Extreme 2 Share this post Link to post Share on other sites
Pullstart 70,767 #35 Posted August 19, 2023 Awesome! 2 Share this post Link to post Share on other sites
Bow_Extreme 583 #36 Posted August 20, 2023 (edited) Almost done. Edited August 20, 2023 by Bow_Extreme 1 8 2 Share this post Link to post Share on other sites
c-series don 12,140 #37 Posted August 20, 2023 Two words, Bad Ass! 2 1 1 Share this post Link to post Share on other sites
Bow_Extreme 583 #38 Posted August 20, 2023 4 minutes ago, c-series don said: Two words, Bad Ass! Thank You! 2 Share this post Link to post Share on other sites
JCM 11,260 #39 Posted August 20, 2023 When you have some serious work to do, it's tough to beat a well maintained 520 Wheel Horse. 4 Share this post Link to post Share on other sites
kpinnc 18,756 #40 Posted August 20, 2023 1 hour ago, Bow_Extreme said: Almost done. That thing is gorgeous! Well done sir! 2 1 Share this post Link to post Share on other sites
Bow_Extreme 583 #41 Posted August 20, 2023 5 minutes ago, kpinnc said: That thing is gorgeous! Well done sir! Thank You! 2 Share this post Link to post Share on other sites
SylvanLakeWH 31,769 #42 Posted August 20, 2023 9 hours ago, c-series don said: Two words, Bad Ass! I don't know... I'd say "Nice @ss"...!!! 5 Share this post Link to post Share on other sites
Pullstart 70,767 #43 Posted August 21, 2023 On 8/19/2023 at 9:06 PM, c-series don said: Two words, Bad Ass! one, two, three, four…. Five words, that’s Bad Ass! 3 Share this post Link to post Share on other sites
Damien Walker 297 #44 Posted August 28, 2023 Beautiful work. Very well done! 1 Share this post Link to post Share on other sites
kpinnc 18,756 #45 Posted August 29, 2023 On 8/20/2023 at 6:37 AM, SylvanLakeWH said: I don't know... I'd say "Nice @ss"...!!! Agreed. Mighty purdy backside. Me likey! Got me thinkin (brace yourselves any time this happens) how my tractors share so many qualities with the Mrs... 1- tough as nails. 2- no matter the years, keeps looking good. 3- works hard... Don't tell her I said so. 4- never ceases to amaze me with what she can accomplish. 5- can tick me off like nothing else but always shows me it's likely something I did wrong... 6- makes me spend money that I normally wouldn't. Sound about right? 5 Share this post Link to post Share on other sites
SylvanLakeWH 31,769 #46 Posted August 29, 2023 Bingo!!! Share this post Link to post Share on other sites
ebinmaine 79,740 #47 Posted August 29, 2023 2 hours ago, kpinnc said: Got me thinkin (brace yourselves any time this happens) 2 hours ago, kpinnc said: how my tractors share so many qualities with the Mrs... 1- tough as nails. 2- no matter the years, keeps looking good. 3- works hard... Don't tell her I said so. 4- never ceases to amaze me with what she can accomplish. 5- can tick me off like nothing else but always shows me it's likely something I did wrong... 6- makes me spend money that I normally wouldn't. Sound about right? That's close for me. #1 is a HUGE understatement. 🥋🥋🥋 2. 3. 4. We're good. 5 and 6... Why I don't know... But they don't apply to me. Ever. 2 Share this post Link to post Share on other sites
