truckin88 104 #1 Posted August 7, 2009 What do I need to know when buying a tiller, what parts have to be there, will the same tiller and belt work on my C-120 and 520-H? Will I need anything special on the tractors Thanks for adivce, Will Share this post Link to post Share on other sites
nylyon-(Admin) 7,880 #2 Posted August 7, 2009 I don't have a tiller, but here is my understanding on what you will need. First on the tractors usually permanently mounted. 1. Rear lift cable and brackets to lift the tiller 2. Rear axle mounting bracket. Then for the tiller: 1. Tiller (obviously) 2. Idler bracket for the belt with springs and associated hardware. 3. Tiller belt and belt guards if available. I would suspect that the tiller would work best on a hydro because of the more variable ground speed, and the hydraulic lift should make it easier to boot. Then of course if you get one, having your local RedSquare members borrowing it once a year is always helpful :thumbs2: Share this post Link to post Share on other sites
truckin88 104 #3 Posted August 7, 2009 coach, you are not located near the train yard in Brewster are you? I work for MNRR, and I always pass by a house with 2 Maroon stripe style tractors (actually black strip) that are in the driveway or on a trailer. Share this post Link to post Share on other sites
nylyon-(Admin) 7,880 #4 Posted August 7, 2009 Nope, that's not me I'm on the other side of town, but I think I know the house you are talking about. Share this post Link to post Share on other sites
