wheelhorse101 0 #1 Posted July 31, 2009 well today was a good day until i went to go load my c-81 loader onto the trailer and clunk there gos the transmission on the darn thing no gears work whats so ever this sucks and i had work to do with it tommarow :thumbs2: Share this post Link to post Share on other sites
nylyon-(Admin) 8,834 #2 Posted July 31, 2009 Maybe it's the key on an axle? Share this post Link to post Share on other sites
WHC-125 4 #3 Posted July 31, 2009 Dan, what happened ? Is it the hub again or inside? Share this post Link to post Share on other sites
d180man 5 #4 Posted July 31, 2009 Hi hope it is not to bad!! we have had that happen too ! did it brake the trans? or just stop moving? :thumbs: Share this post Link to post Share on other sites
wheelhorse101 0 #5 Posted July 31, 2009 just stoped moving and in every gear it dosent do anything axles arnt spinning either so im not sure what i have to do now :thumbs2: Share this post Link to post Share on other sites
WHC-125 4 #6 Posted July 31, 2009 just stoped moving and in every gear it dosent do anything axles arnt spinning either so im not sure what i have to do now Did you check the belt? And try low range. Share this post Link to post Share on other sites
wheelhorse101 0 #7 Posted July 31, 2009 checked it all when its running i can shift threw all the gears without putting the clutch in not good Share this post Link to post Share on other sites
Jim_M 179 #8 Posted July 31, 2009 Broken key between the driven pulley and transmission input shaft? Share this post Link to post Share on other sites
wheelhorse101 0 #9 Posted August 4, 2009 i fixed it thank god it was only the key for the pully on the tranny :thumbs2: Share this post Link to post Share on other sites
stevebo-(Moderator) 8,604 #10 Posted August 4, 2009 Dan, Glad to hear it worked out. Rember you don't have to work that thing too hard... Share this post Link to post Share on other sites
