JeffG 0 #1 Posted May 23, 2023 Looking for a replacement rectifier for a C120. Appreciate your help. Jeff Share this post Link to post Share on other sites
moe1965 766 #2 Posted May 23, 2023 I got one off Amazon not to long ago. Just use the part number that is on it for your search and it should pop up. Also save your old one to reference what connecter goes where the new one I had didn't have any markings on it Share this post Link to post Share on other sites
953 nut 60,629 #3 Posted May 23, 2023 I Save Tractors is a good reliable source of quality parts. The attached link is for the proper Regulator/Rectifier for your . https://isavetractors.com/regulator-rectifier-for-kohler-briggs-and-stratton-and-tecumseh-engines-with-stator-charging-system/ 1 Share this post Link to post Share on other sites
peter lena 9,327 #4 Posted May 23, 2023 @JeffG note 5th picture down , that area is a gold mine for improvement , see the battery cable going to engine corner / frame ? that comes from battery ground bolt and enhances rectifier grounding , those cooling tins , for a rectifier mount , don,t do a solid job , also note , battery tender plug in ? on choke cable , always ready for a simple plug in , pete Share this post Link to post Share on other sites
JeffG 0 #5 Posted May 23, 2023 9 hours ago, moe1965 said: I got one off Amazon not to long ago. Just use the part number that is on it for your search and it should pop up. Also save your old one to reference what connecter goes where the new one I had didn't have any markings on it thank you for the feedback! Jeff Share this post Link to post Share on other sites
JeffG 0 #6 Posted May 23, 2023 9 hours ago, 953 nut said: I Save Tractors is a good reliable source of quality parts. The attached link is for the proper Regulator/Rectifier for your . https://isavetractors.com/regulator-rectifier-for-kohler-briggs-and-stratton-and-tecumseh-engines-with-stator-charging-system/ Awesome - thank you for the link! Jeff Share this post Link to post Share on other sites
JeffG 0 #7 Posted May 23, 2023 6 hours ago, peter lena said: @JeffG note 5th picture down , that area is a gold mine for improvement , see the battery cable going to engine corner / frame ? that comes from battery ground bolt and enhances rectifier grounding , those cooling tins , for a rectifier mount , don,t do a solid job , also note , battery tender plug in ? on choke cable , always ready for a simple plug in , pete appreciate the help! jeff Share this post Link to post Share on other sites
peter lena 9,327 #8 Posted May 24, 2023 @JeffG like you when I started with wheel horse , I encountered problem areas . rarely put it back exactly as was set up , detailed in / eliminated reason of failure . that mind set upsets many , not my intent . but to eliminate the chronic issue . to me , a repetitive problem is what you want . leads you right to the reason / cause . also note in first picture , the elastic nut going to the greaseable flange bearing ? that was also a chronic buzzing area , not any more . just some ideas , pete Share this post Link to post Share on other sites
