Aubreysheppard 1 #1 Posted May 20, 2023 i have got a 1980s wheel horse c125 with a 161 kohler engine it misfires and runs well at low levels pulls ok but at higher revs and runs eraticly 1 Share this post Link to post Share on other sites
Sparky-(Admin) 24,251 #2 Posted May 20, 2023 @Aubreysheppard I split out your question into its own topic so it would get more attention. I would start with the basics .. spark plug replacement, points and how they’re set. Then carburetor adjustment or a full rebuild or cleaning. 2 1 Share this post Link to post Share on other sites
Pullstart 68,637 #3 Posted May 20, 2023 (edited) @Aubreysheppard! Could you verify the engine model number? A K161 (7hp) is a pretty small engine to be in a C-125 (originally a 12 hp) Edited May 20, 2023 by Pullstart 1 Share this post Link to post Share on other sites
953 nut 63,560 #4 Posted May 20, 2023 A bad condenser will give those same symptoms. The Kohler 230722 Condenser fits all battery ignition single cylinder and twin cylinder from the K-90 to the K-582. The 235786 condensers are for the magneto equipped Kohler engines only K-161 to K-301 The unit of measure for a condenser is the Farad. Many electronic components like radios and TVs use capacitors that are in the microfarad range (ten to the minus six power Farads) and our small engines use a condenser that is in the nanofarad range (ten to the minus ninth power Farads) which is based on the voltage range they work in. A magneto ignition system uses a 100 to 250 nF condenser and a battery ignition system uses a 200 to 500 nF condenser. A good multi-meter will have a capacitor testing function. Armed with this information you can walk into your auto parts store and get a very confused look on the face of the person on the other side of the counter. The capacitance is not listed on the package and probably not in any of the on-line data they have for the condensers they stock. You just have to go by the application chart and be sure that the condenser you are buying is for the type ignition system your engine has, not just the horsepower or engine size. If an engine idles well, but runs erratically when revved up, like it hits and misses, pops and backfires, then chances are, it needs a new condenser/capacitor. And always install a condenser/capacitor with the wire facing downward so rain water and/or when washing off engine, water will not enter inside condenser/capacitor, ruining it. With water inside the condenser, this will also allow it to idle well, but cause it to run erratically when revved up. What is a farad (F)? A farad (F) is the standard unit of capacitance (C) in the International System of Units (SI). It indicates the ability of a substance to hold an electric charge. The value of most electrical capacitors is expressed in farads, microfarads (µF) or nanofarads (nF) 2 Share this post Link to post Share on other sites
peter lena 9,643 #5 Posted May 20, 2023 @Aubreysheppard think you have a number of issues, electrical is fefinetly in there , have a fuel filter on that unit ? drop the carb bowl ? cracked , chaffed wiring ? corrosive connections? recently recovered a horse that was packed with grass and corrosive connections , wire connections were power dry with electrical shorting . might also try running it on a separate gallon of heavily treated fresh gas . pete Share this post Link to post Share on other sites
clueless 3,345 #6 Posted May 20, 2023 Did you put the K161 engine it or someone else? Share this post Link to post Share on other sites
