Crow Horse 8 #1 Posted July 30, 2009 The muffler pipe nipple on my B-80 is "rust welded" in the block. It appears that a previous owner had tried to remove it and in doing so, they managed to make the nipple oval at one end. What are my options? When i resolve the pipe nipple issue, I do want to cob up an exhaust system that doesn't spew exhaust in my face...... Anyone have somee pics of their home brew system? All Good Medicine, Crow Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted July 30, 2009 Cut the nipple off within 3/8" to 1/4" of the block and use a hacksaw blade to cut a slot in the bottom of the pipe. (parallel with the pipe - don't worry if it cuts into the threads a little) Once you have the slot cut, hit the end of the pipe you left when you cut it off (see why you leave that little bit sticking out? ) and collapse the remaining piece of the pipe until it breaks loose and comes out. Muffler style is entirely your call. Do you need it to be semi-quiet or doesn't it matter? Share this post Link to post Share on other sites
