ANTPER 208 #1 Posted May 13, 2023 Hello I have a Toro Classic 310-08 Kohler and I'm in need of the air filter cover and curious are they available to buy new or only what's around in the field. I have one from a C101 but has a flat air cleaner base plate but this classic has a dome shape base and needs a taller cover to cover the entire filter when installed. Thanks in advance. Anthony Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,852 #2 Posted May 13, 2023 What year is your tractor or what is the model number? Need that to look up the engine parts list. 1 Share this post Link to post Share on other sites
ANTPER 208 #3 Posted May 14, 2023 17 hours ago, gwest_ca said: What year is your tractor or what is the model number? Need that to look up the engine parts list. Unfortunately the info tag sits right where the choke and throttle cables run and that info rubbed off. Its the Magnum Ten series. Being a Toro classic probably narrows down the year so has to be 1986 or later? Bought it used. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,852 #4 Posted May 14, 2023 1987-1991 310-8 using Kohler M10S-461521 or M10-461521 https://www.partstree.com/models/m10-461521-kohler-magnum-engine-made-for-wheel-horse-10hp-7-5kw Air cleaner - this list does not look complete for some reason. https://www.partstree.com/models/m10-461521-kohler-magnum-engine-made-for-wheel-horse-10hp-7-5kw/air-intake-1-10-508-rev-3-15-2006-to-show-group-description-0/ 2 Share this post Link to post Share on other sites
ANTPER 208 #5 Posted May 16, 2023 On 5/14/2023 at 9:39 AM, gwest_ca said: 1987-1991 310-8 using Kohler M10S-461521 or M10-461521 https://www.partstree.com/models/m10-461521-kohler-magnum-engine-made-for-wheel-horse-10hp-7-5kw Air cleaner - this list does not look complete for some reason. https://www.partstree.com/models/m10-461521-kohler-magnum-engine-made-for-wheel-horse-10hp-7-5kw/air-intake-1-10-508-rev-3-15-2006-to-show-group-description-0/ Thanks very much. At least I now know what I'm after. Appears the Toro edition has different style non cylindrical type air cover set up Share this post Link to post Share on other sites
