MJBaldie 4 #1 Posted May 10, 2023 I have a voltage controller purchased in the UK by Bosch that is a replacement for a delco controller, it has 3 connections on the front marked L, BATT and F. It also has a connector underneath that is unmarked, does anybody know if this is the GEN connector ? Share this post Link to post Share on other sites
953 nut 62,958 #2 Posted May 11, 2023 2 hours ago, MJBaldie said: connector underneath that is unmarked, does anybody know if this is the GEN connector Yes it is, hooks up to the "A" terminal of your Starter/Generator. 1 Share this post Link to post Share on other sites
MJBaldie 4 #3 Posted May 11, 2023 Thank you, I have wired it up and had it running, I know it’s fixed to the engine block but it seems run very hot. I have put a multimeter on it and at tickover it is putting out 14.5-15 volts, is that too much, can regulator be adjusted ? Share this post Link to post Share on other sites
ri702bill 10,546 #4 Posted May 11, 2023 Take a look at these - scans of OLD school faded originals.....enjoy. Bill Delco Remy Regulator Manual 1R-116.pdf delco_remy_regulator_service 1R-111.pdf DELCO-REMY_SERVICE_BULLETIN.pdf Share this post Link to post Share on other sites
