Gregor 4,847 #1 Posted May 10, 2023 I have heard it said more than once, if you have a Tecky carb, and you shake it, and it doesn't rattle, you have an irreparable problem. Any truth to this? Thanks Greg 1 Share this post Link to post Share on other sites
ebinmaine 74,572 #2 Posted May 10, 2023 @Handy Don 5 hours ago, Gregor said: I have heard it said more than once, if you have a Tecky carb, and you shake it, and it doesn't rattle, you have an irreparable problem. Any truth to this? Thanks Greg I've heard that phrased more along the lines of it needing to be deep cleaned. I believe there are quite a few Tecumseh carbs that the main needle can't be removed because it's drilled after installation. That too can be solved by purchasing a rebuild kit that has a needle with grooves of a certain type. What engine is this on? Share this post Link to post Share on other sites
ri702bill 10,063 #3 Posted May 10, 2023 (edited) 5 hours ago, Gregor said: I have heard it said more than once, if you have a Tecky carb, and you shake it, and it doesn't rattle, you have an irreparable problem. Any truth to this? Thanks Greg From my experience, yes. The emulsion tube has a steel check ball in it - you get water in the carb, and steel equals rust. The ball is what makes the rattle sound - if the ball is rusted in place at the bottom, no fuel can enter the tube and that means NO idle circuit. BUT - if you only need the high speed circuit, like on a generator, you MAY be OK. Eric referred to "deep cleaning" - a few sessions in an Ultrasonic cleaner may do the trick... Look at the section view on page 10 of the attached PDF - clearly shows the little bugger... Bill Tecumseh Manual 3-10 HP.pdf Edited May 10, 2023 by ri702bill 1 Share this post Link to post Share on other sites
rmaynard 16,589 #4 Posted May 10, 2023 (edited) They can be repaired. See my thread on Tecumseh rebuild. https://www.wheelhorseforum.com/topic/92440-how-to-rebuild-a-tecumseh-v60-carburetor/#comment-959555 Edited May 10, 2023 by rmaynard 1 Share this post Link to post Share on other sites
Handy Don 14,658 #5 Posted May 10, 2023 (edited) 4 hours ago, rmaynard said: They can be repaired. See my thread on Tecumseh rebuild. https://www.wheelhorseforum.com/topic/92440-how-to-rebuild-a-tecumseh-v60-carburetor/#comment-959555 Determined effort can save them, yes. Rust will make it hard, but so far I’ve only encountered varnish from evaporated gas and a long session in a borrowed ultrasonic tank and some sharp knocks got it loose. Edited May 10, 2023 by Handy Don 1 Share this post Link to post Share on other sites
ri702bill 10,063 #6 Posted May 10, 2023 1 hour ago, Handy Don said: and some sharp knocks got it loose. Treat it like a red-headed stepchild!!! Share this post Link to post Share on other sites
