Wvtroutbum81 304 #1 Posted May 9, 2023 So i built a new deck for my 312-8, i am also new to working on WH. Having a hard time getting it to cut even. Would someone more knowledgeable than me please guide me through the process? Share this post Link to post Share on other sites
daveoman1966 3,882 #2 Posted May 9, 2023 (edited) First, is it mounted... hung... on the tractor correctly. Study this image of the FORK to be sure. Secondly, are the blades SHARP and mounted correctly.... (they can be mounted upside-down). Third.... is the PTO to Deck belt the RIGHT BELT?...and is the tension set properly? It should deflect 1" or so mid-way of the PTO bell and the front mule drive. 4th... do the 3 deck spindles turn free by hand, with no noticeable drag...and IS the deck TENSION Idler arm/pulley free floating. If not, clean out the debris from under the floating arm (J). (This is a 48" deck...they're all the same setup). Edited May 9, 2023 by daveoman1966 1 1 Share this post Link to post Share on other sites
Wvtroutbum81 304 #3 Posted May 9, 2023 Yes its mounted correctly, everything spins free and belt tension is good. if someone could pm me and talk on phone would be easier to explain Share this post Link to post Share on other sites
Wvtroutbum81 304 #4 Posted May 10, 2023 Yes its mounted correctly, everything spins free and belt tension is good. if someone could pm me and talk on phone would be easier to explain Do you use the dial height to adjust or use the attachment lift lever to raise and lower Share this post Link to post Share on other sites
stevasaurus 23,685 #5 Posted May 10, 2023 Use the dial to adjust the height of the cut...the lift lever just raises the deck off the ground. One thing that can make a difference...the air pressure in your tractor tires. I think rear tires should be 8 to 10 PSI..front around 6 PSI. 1 Share this post Link to post Share on other sites
8ntruck 8,845 #6 Posted May 10, 2023 Might want to check the shaft that connects the gage wheels for twist. Are both of the gage wheels the same diameter? Just some brainstorming type thoughts. 1 Share this post Link to post Share on other sites
Rick3478 445 #7 Posted May 10, 2023 2 hours ago, stevasaurus said: Use the dial to adjust the height of the cut...the lift lever just raises the deck off the ground. One thing that can make a difference...the air pressure in your tractor tires. I think rear tires should be 8 to 10 PSI..front around 6 PSI. That's wrong. Dial adjusts minimum height for some implements, like tiller or snow blade, but is not used for mowers and should be set as low as it will go. Cutting height is set by gage wheels, and front/back angle by the trunnion on the rear of the deck. 1 1 Share this post Link to post Share on other sites
Rick3478 445 #8 Posted May 10, 2023 17 hours ago, Wvtroutbum81 said: So i built a new deck for my 312-8, i am also new to working on WH. Having a hard time getting it to cut even. Would someone more knowledgeable than me please guide me through the process? So what do you mean by "built a new deck"? Refurbished an existing deck, or start from scratch? If from scratch, does it have gage wheels on the back? Leveling yoke/linkage similar to WH? Gage wheels on the front? A picture or drawing might be helpful. Share this post Link to post Share on other sites
8ntruck 8,845 #9 Posted May 10, 2023 Might want to check the front to back tilt as well. Most Wheel Horse decks want the front of the deck to be 1/4" lower than the back. That is adjusted by adjusting the nut on the threaded link that is near the centre rear of the deck. That rod runs front to back on the deck. Share this post Link to post Share on other sites
stevasaurus 23,685 #10 Posted May 10, 2023 Rick, I misunderstood what he meant when he said dial. I was thinking there might be a dial on the deck itself. I know the star dial is for the lift lever. My older 36" rear discharge decks have a pull knob on the deck that adjusts the height of the deck. Share this post Link to post Share on other sites
Wvtroutbum81 304 #11 Posted May 10, 2023 Its all new, this was before i put the carrier frame on. I unbolted it from the old shell and put it onto the new one. i think i might have figured it out, the chain that connects lift arm to deck is short, guessing it broke in the past and was not fixed properly. The lift arm will not raise or lower the deck. what length should the chain be? Share this post Link to post Share on other sites
Rick3478 445 #12 Posted May 10, 2023 It's really hard to see with the deck mounted, and almost impossible to get your hands in to adjust. I *think* there are like 4 links of chain plus the screw eye and trunnion on top. Someone else chime in if they have one far enough apart to see. I often thought of trying to figure a better setup, but once adjusted it hasn't needed any further fussing, so I didn't. Ideally, the lift handle should just latch into the up position with the deck pulled tight against the bottom of the tractor. Share this post Link to post Share on other sites
8ntruck 8,845 #13 Posted May 11, 2023 The trunoin that attaches to my deck slides on a rod that hooks into the lift arm. The bottom end of the rod is threaded to allow for adjustment of the up position. Distance between the reunion and the hook in the lift rod n the order of 4 to 6 inches. Working from memory here, which does not work as well as it used to. Share this post Link to post Share on other sites
Wvtroutbum81 304 #14 Posted May 21, 2023 Figured it out, this was turned all the way out. Adjusted it and it works now. Thanks for help Share this post Link to post Share on other sites
