Docwheelhorse 2,875 #1 Posted May 5, 2023 Happy Weekend All, Hope to see a few of you at Zagray Farm tomorrow. So... am I rich? What are these off of? Find it odd there drilled for lugnut / bolt access... you could get a socket in there but lugbolt will fall into rim and it's probably impossible to get them started through these holes. Tony 1 1 1 Share this post Link to post Share on other sites
c-series don 11,497 #2 Posted May 5, 2023 I’ve never seen those before. I do remember the C-195 had weights that had holes in them like that but they were for a 15” rim I believe. Yours looks like a 12” rim ? Share this post Link to post Share on other sites
Docwheelhorse 2,875 #3 Posted May 5, 2023 11 minutes ago, c-series don said: I’ve never seen those before. I do remember the C-195 had weights that had holes in them like that but they were for a 15” rim I believe. Yours looks like a 12” rim ? Yep.... just run of the mill 23x8.5x12 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,604 #4 Posted May 5, 2023 I like them no matter what they are off of 4 Share this post Link to post Share on other sites
CasualObserver 3,415 #5 Posted May 6, 2023 The look like Case Ingersoll to me. Maybe mounted reverse of how you usually see them? 2 Share this post Link to post Share on other sites
CasualObserver 3,415 #6 Posted May 6, 2023 Found an example 2 Share this post Link to post Share on other sites
Docwheelhorse 2,875 #7 Posted May 6, 2023 3 hours ago, CasualObserver said: Found an example Huh... so do the CI guys fight over them and what's the point of lug holes... Share this post Link to post Share on other sites
RandyLittrell 3,944 #9 Posted May 7, 2023 23 hours ago, Docwheelhorse said: Huh... so do the CI guys fight over them and what's the point of lug holes... If htey will go over the lug bolts, you can stack two on one wheel without sticking out a bunch. The ones on the tractor are turned the opposite way. Randy Share this post Link to post Share on other sites
ebinmaine 77,554 #10 Posted May 9, 2023 Doc, what's the actual weight on those? Share this post Link to post Share on other sites
