Thompson1276 257 #1 Posted May 5, 2023 Just low rided my 856, that has a HH100 Tecumseh (big block short frame) with points. And she rips but even better fits the rat rod look. Yes I have the drive belt guard just need to shop it a little to make it fit. Took me 6-8 hours to do only specials tools I needed was a angle grinder if anyone was thinking about doing it too and I have it held it with the bottom holes for th transmission at the top holes on the frame and then brackets to hold the top in place if you don’t it’ll wanna fold in on itself 2 2 2 Share this post Link to post Share on other sites
AlexR 2,825 #2 Posted May 5, 2023 Got a great look going on there. 1 Share this post Link to post Share on other sites
Thompson1276 257 #4 Posted May 5, 2023 14 minutes ago, AlexR said: Got a great look going on there. Thank you I’d like to improve it a little more make it now instead of use , now safe 😅 Share this post Link to post Share on other sites
wallfish 19,707 #6 Posted May 5, 2023 28 minutes ago, Thompson1276 said: Thank you I’d like to improve it a little more make it now instead of use , now safe 😅 Looks good The biggest thing safety wise is those steering spindles. If it's just relying on those snap rings to support them and hold the weight don't go too fast because eventually they will indeed fail and it's going to stop FAST too. Especially when doing wheelies and coming down hard. 2 5 Share this post Link to post Share on other sites
TJ5208 1,841 #7 Posted May 5, 2023 2 hours ago, Thompson1276 said: Just low rided my 856, that has a HH100 Tecumseh (big block short frame) with points. And she rips but even better fits the rat rod look. Yes I have the drive belt guard just need to shop it a little to make it fit. Took me 6-8 hours to do only specials tools I needed was a angle grinder if anyone was thinking about doing it too and I have it held it with the bottom holes for th transmission at the top holes on the frame and then brackets to hold the top in place if you don’t it’ll wanna fold in on itself Very cool Share this post Link to post Share on other sites
Thompson1276 257 #8 Posted May 5, 2023 8 hours ago, wallfish said: Looks good The biggest thing safety wise is those steering spindles. If it's just relying on those snap rings to support them and hold the weight don't go too fast because eventually they will indeed fail and it's going to stop FAST too. Especially when doing wheelies and coming down hard. Yeah the snap rings I noticed I’m going to have to put something stronger at the end, and yeah she dosnt do wheelies, but she use to prob because she’s lower, but she also does around 20 mph Share this post Link to post Share on other sites
953 nut 65,110 #9 Posted May 5, 2023 23 minutes ago, Thompson1276 said: she dosnt do wheelies, but she use to prob because she’s lower, but she also does around 20 mph Can't have your cake and eat it too. The larger engine pulley and small transmission pulley increase ground speed but reduce torque to the wheels. Like your drive belt idler setup, gives the driven pulley a good amount of surface contact with the belt. Needs a belt guard to catch the belt slack when the clutch is pushed down but I think you already knew that. 2 Share this post Link to post Share on other sites
Thompson1276 257 #10 Posted May 5, 2023 36 minutes ago, 953 nut said: Can't have your cake and eat it too. The larger engine pulley and small transmission pulley increase ground speed but reduce torque to the wheels. Like your drive belt idler setup, gives the driven pulley a good amount of surface contact with the belt. Needs a belt guard to catch the belt slack when the clutch is pushed down but I think you already knew that. Yeah that was my goal to make it not slip and does better I got to say it uses the same belt to drive the 42” mower decks so I have hundred of em if it breaks and pulleys off the old PTO pulleys and one off a tiller pto pulley she’s rigged but that’s why I like it 1 Share this post Link to post Share on other sites
Pullstart 69,605 #11 Posted May 5, 2023 2 hours ago, Thompson1276 said: Yeah the snap rings I noticed I’m going to have to put something stronger at the end, and yeah she dosnt do wheelies, but she use to prob because she’s lower, but she also does around 20 mph Could you drill and tap the spindles and run a 3/8” bolt with a heavy washer? Little Loc-Tite and no worries! Share this post Link to post Share on other sites
wallfish 19,707 #12 Posted May 5, 2023 (edited) 19 minutes ago, Pullstart said: Could you drill and tap the spindles and run a 3/8” bolt with a heavy washer? Little Loc-Tite and no worries! And if you add some thrust washers or thrust roller washers it will take most of the spindle turning forces off of trying to turn the bolts. Shave the TOP of the axle if you need more spindle room on the bottom. Leave the bottom flat. Edited May 5, 2023 by wallfish 1 Share this post Link to post Share on other sites
brians306 23 #13 Posted May 5, 2023 2 hours ago, Thompson1276 said: Yeah the snap rings I noticed I’m going to have to put something stronger at the end, and yeah she dosnt do wheelies, but she use to prob because she’s lower, but she also does around 20 mph Weld washers to the ends of the spindles. in place of the snap rings. Share this post Link to post Share on other sites
Pullstart 69,605 #14 Posted May 5, 2023 13 minutes ago, brians306 said: Weld washers to the ends of the spindles. in place of the snap rings. And loose all serviceability? Share this post Link to post Share on other sites
brians306 23 #15 Posted May 5, 2023 1 hour ago, Pullstart said: And loose all serviceability? Not really just enough weld from the washer to the top of the spindle Share this post Link to post Share on other sites
Pullstart 69,605 #16 Posted May 5, 2023 14 minutes ago, brians306 said: Not really just enough weld from the washer to the top of the spindle I still can’t understand how that would ever come apart for service? Share this post Link to post Share on other sites
