Jerrymaxx 1 #1 Posted April 28, 2023 (edited) I am in need of a sediment bowl for a 702. Butterfingers got the best of me and the old one broke. Edited April 28, 2023 by Jerrymaxx Wrong model number 1 Share this post Link to post Share on other sites
ri702bill 10,642 #2 Posted April 28, 2023 Welcome - but your request is best posted in the Wanted section of the Forum Classifieds.... There are aftermarket reproductions, but, the size of the glass bowl and gasket most likely be different from an original... Bill Share this post Link to post Share on other sites
oliver2-44 11,075 #3 Posted April 28, 2023 You can get a complete new one on ebay or from Isavetractors.com , but as mentioned above it will be a slightly different size. Share this post Link to post Share on other sites
squonk 44,897 #4 Posted April 28, 2023 Many places sell the sediment bowls. Napa sells the individual parts Complete BKS65545 bowl Old # 730-9505 (New Number is BKSO4102 but not in system) Brass Screen BKS04100 Gasket BKS04103 "Sediment Bowl" is French for "Gas Leak" 2 Share this post Link to post Share on other sites
wallfish 18,791 #5 Posted April 28, 2023 (edited) 20 minutes ago, squonk said: "Sediment Bowl" is French for "Gas Leak" Or water separator. They do collect water that would normally pass through the average small engine filters. With a good gasket they don't leak but all of the old ones do because the gasket and the little O ring seal on the valve are always dry rotted. I like them on the old stuff but always couple it with a paper filter too. Stens makes one that is the same exact size and the fittings are the same. Direct bolt on. I've seen them at tractor supply too. http://www.psep.biz/store/small_engine_fuel_filters.htm Edited April 28, 2023 by wallfish 1 Share this post Link to post Share on other sites
squonk 44,897 #6 Posted April 28, 2023 22 minutes ago, wallfish said: Or water separator. They do collect water that would normally pass through the average small engine filters. With a good gasket they don't leak but all of the old ones do because the gasket and the little O ring seal on the valve are always dry rotted. I like them on the old stuff but always couple it with a paper filter too. Stens makes one that is the same exact size and the fittings are the same. Direct bolt on. I've seen them at tractor supply too. http://www.psep.biz/store/small_engine_fuel_filters.htm If I had a dime for every sediment bowl gasket I sold at Napa, I could buy your Wed. Night dinner! Share this post Link to post Share on other sites
wallfish 18,791 #7 Posted April 28, 2023 1 hour ago, squonk said: If I had a dime for every sediment bowl gasket I sold at Napa, I could buy your Wed. Night dinner! Why, did they leak after the NAPA gasket was used? 1 Share this post Link to post Share on other sites
squonk 44,897 #8 Posted April 28, 2023 5 minutes ago, wallfish said: Why, did they leak after the NAPA gasket was used? No they just leak. A lot of them came originally with a cork gasket. Replacement was rubber. One guy bought 10 one day. ( He had a pile of old Case and Olivers.) Share this post Link to post Share on other sites
