Countdown To Christmas!
usmc041127
hobbs hr meter
usmc041127
anyone know what part number or hr meter number that goes in the 520h. Id like to put in a new one with the fresh motor to keep the best track and i know it works.
nylyon
It may depend on the year of your 520, a 1990 takes Toro PN: 113469, where as a 1994 uses PN: 78-0020 (66-2950)
usmc041127
hmm i have no clue the yrs of my tractor but it has hub caps and i was told the early ones cane with them
nylyon
I think that most of them came with Hub Caps. The ID tag should be under the seat.
usmc041127
will it specificly tell me the year or do i need to look the number up
nylyon
It will look something like 41-20OE02 then we can look up the year.
1988 - 1990 used part number 113469
1991 - 1997 use part numbers which supersede to 66-2950
usmc041127
i will look it up when i get home i dont have the inter net there il report back tommorrow
nylyon
I pulled the following information from www.milacalawn.com using their viewer searching for 520-H
1988 - 31-20OE01
1989 - 31-20OE02
1990 - 41-20OE01
1991 - 41-20OE02
1992 - 41-20OE03
1993 - 73501 or 73520 with (SN 39000001-39999999)
1994 - 73501 or 73520 with (SN 49000001-49999999)
1995 - 73501 or 73520 with (SN 59000001-59999999)
1996 - 73501 or 73502 or 73521 with (SN 69000001-69999999)
1997 - 73502 or 73521 with(SN 7900001-7999999)
usmc041127
I dont have a tag on mine. The only thing i seen was a bar code acualy on the seat with a number that been blacked out. I figured they had to have put it on somethng else that wont be replaced as easaly. Seats come and go on a garden tractors. I didn't see a tag or anything on the fender deck or anything.
usmc041127
is there any other way to narrow it down? I dont have a foot control and my pto is manual, the lever for the deck is on the let side and the lever for the transmission is on the middle pan. i don't know what elseto look for. the hr meter is located lower botom right on the dash panel. it just says hobbs on top and sw on the bottom.
lotus1967
Is there no part # on the old meter?
WheelHorse_of_course
Unless you are a "purist" any 12 volt meter that will fit in the hole will do.
I got one off ebay.
mcwh1950
usmc041127
if you 520h have decal like this it's a 1988 or 89
if decal are like this it's a 1990 or later.
hope this help some
Nick
If it is a 520-H the front axle design and hydro motion lever location should help narrow down the year. Im normally a year off but didnt the hydro control change to dash mounted in 1990 or 1991? The swept forward axle was added to the 520-H in 90 and reduction steering in 91.
usmc041127
mine has to be an older one becaude its a wheelhorse not a toro i dont care what meter its is as long as it fits right and works.
Buzz
Post all of the numbers off your Onan engine and we can narrow it down pretty close.
USMC
Go to ebay and search "hour meter" and there are a bunch on there.
Other than 12 volt they are pretty much interchangeable other than the mounting.
If yours mounts with screws around the edge (many of the hobbs mount this way) then that is the key feature you will look for.
There is a hobbs with the outside screws on there now for a BIN of 15.00
Best of luck,
And thanks for serving,
:thumbs: :thumbs2:
gwgdog66
USMC,
My old C-160 uses PN# 105868. It is a round one, with a bracket on the back side.
Like others have posted, any 12 volt meter will work as long as it fits the mounting hole.
We can narrow down the year if you post the engine numbers, if they are still legible.
