Skwerl58 843 #1 Posted April 22, 2023 I have been rewiring the 1054 that I have had for a while. I posted last week about the replacement engine. The tractor still has the original split key and starter button but no longer has coil ignition. It does have points but the plug wire comes from behind the flywheel cover and another wire also comes from below it. The generator light has been replaced with an amp gauge. I rewired it like it was wired when I got it except the colors. I need to know where the other light switch wire goes and also if the other wiring appears correct. From the key switch the blue wire goes to the points and condenser and the black wire from behind the flywheel, is this correct for this ignition system. Any help is needed. I will clean up the wiring after it is running. Thanks!! 2 Share this post Link to post Share on other sites
953 nut 69,544 #2 Posted April 23, 2023 3 hours ago, Skwerl58 said: I need to know where the other light switch wire goes and also if the other wiring appears correct. Use this diagram as a guide with the exception of the S/G which would be like the 953 wiring. 1 Share this post Link to post Share on other sites
