Brockport Bill 1,928 #1 Posted April 22, 2023 what is the Work horse 1800 gray color name to buy -- prefer the Rustoleum brand -- not sure if its a "flater" gray... or more a pewter -- this is a 1800 mfg 1984 - thanks 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,441 #2 Posted April 22, 2023 They used two different grays 3 Share this post Link to post Share on other sites
c-series don 9,966 #3 Posted April 22, 2023 I used the 1982 Lincoln gray, non metallic because that was the correct color for the 1984 Work Horse GT-1800. I purchased it through a body shop. I’m not sure what Rustoleum color would be close? Smoke gray is too dark though. 2 Share this post Link to post Share on other sites
Brockport Bill 1,928 #4 Posted April 22, 2023 4 hours ago, gwest_ca said: They used two different grays when you say they used "2 different grays" are you referring to 2 different grays during the '84 model production of the gt 1800 --- or are you referencing the difference of the two grays between the model 1848 from '82-83 versus the '84 of the 1800? thanks 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,441 #5 Posted April 23, 2023 The color changed between years. Just wanted you to know that in case you did not. One is metallic and one is not. If you click on the fuzzy part of the link you can read about it. 1 Share this post Link to post Share on other sites
Lee1977 7,185 #6 Posted April 26, 2023 If using Rustoleum. I think their Pewter gray will be closer to the right color. 1 Share this post Link to post Share on other sites
