hhookatrophy 1 #1 Posted April 20, 2023 What's the best way to get pulleys off the spindle bearing tower. First replacement since new in 1987. 312-8 36 inch rear discharge deck . First line I.D.# 0536mro4.........70246 2nd line 7 211. Thanks so much in advance. 1 Share this post Link to post Share on other sites
953 nut 62,233 #2 Posted April 20, 2023 Here are a few threads that will give you some ideas to work with. 1 Share this post Link to post Share on other sites
oliver2-44 10,980 #3 Posted April 21, 2023 (edited) Looks like 953 has you off to a good reading start. Penetrating oil and time are your friend, they didn't rust on their overnight. I've had to use a rose bud torch to heat them on one stubborn spindle pulley. Edited April 21, 2023 by oliver2-44 Share this post Link to post Share on other sites
daveoman1966 3,879 #4 Posted April 21, 2023 With the blades off, set the bottom side of the spindle into the hollow of a cement block. Remove grease zerk and thread top nut back on to where it is level with the top of the spindle shaft. Hold the flat side of a ball peen hammer on the top of the spindle shaft and, with a BFH, smack that ball peen it like you got a pair. The 'shock' usually pops the shaft down thru the pulley....top nut will stop it from dropping out. This usually works for me. Share this post Link to post Share on other sites
peter lena 9,471 #5 Posted April 21, 2023 @bds1984 notice the deck to spindle hub bolts in picture ? use that nail puller , as a rocker for leverage , right up against the hub of the pulley . the solid mechanical leverage , and lubricant , with 2 bars makes pulley removal . easy , push both bars out at the same time . pops right off . great time to think about a lucas green hi temp grease , clean out and refill on new bearings . all my decks have this , very quiet , pete Share this post Link to post Share on other sites
bds1984 1,503 #6 Posted April 22, 2023 On 4/21/2023 at 8:33 AM, peter lena said: @bds1984 notice the deck to spindle hub bolts in picture ? use that nail puller , as a rocker for leverage , right up against the hub of the pulley . the solid mechanical leverage , and lubricant , with 2 bars makes pulley removal . easy , push both bars out at the same time . pops right off . great time to think about a lucas green hi temp grease , clean out and refill on new bearings . all my decks have this , very quiet , pete Thanks for the reminder. I've used prybars for this in the past. This was the ONLY deck I had zero luck on removing the pulley. That deck and tractor have been long gone now as someone wanted it more than me and came with a Dodge Caravan that surprisingly swallowed up the tractor, deck, and lots more junk I didn't need. 1 Share this post Link to post Share on other sites
peter lena 9,471 #7 Posted April 22, 2023 @bds1984 always taking advantage of opportunity , making my herd smaller as I age , pete Share this post Link to post Share on other sites
