ebinmaine 81,289 #76 Posted April 16, 2023 30 minutes ago, Oldskool said: A bit of tinkering this afternoon. I still have some stuck pivot points to free up. I'm afraid I may have to put heat to them. I'm hoping not for the paints sake. I've come to the realization that ever k series carb I have is in need of major overhauling. I tried mis matching enough carb parts to get it running but nope no run. Just alot of wasted gas and effort. You try the Hillman washers yet? 1 Share this post Link to post Share on other sites
Oldskool 6,679 #77 Posted April 16, 2023 2 hours ago, ebinmaine said: You try the Hillman washers yet? Not yet. They need more then just those 1 Share this post Link to post Share on other sites
ebinmaine 81,289 #78 Posted April 16, 2023 1 hour ago, Oldskool said: Not yet. They need more then just those Bottom shaft bore bad too? Share this post Link to post Share on other sites
Oldskool 6,679 #79 Posted April 17, 2023 1 hour ago, ebinmaine said: Bottom shaft bore bad too? That I'm not sure of that yet. All need the top bore fixed. One also needs a float and all need bowl and mounting gaskets. Share this post Link to post Share on other sites
ebinmaine 81,289 #80 Posted April 17, 2023 7 hours ago, Oldskool said: That I'm not sure of that yet. All need the top bore fixed. One also needs a float and all need bowl and mounting gaskets. Send em down Mike. No extra floats here but I'll take care of the top and gaskets. 1 Share this post Link to post Share on other sites
Oldskool 6,679 #81 Posted April 17, 2023 59 minutes ago, ebinmaine said: Send em down Mike. No extra floats here but I'll take care of the top and gaskets. Unfortunately none of them are the #30 carb with the correct choke lever Share this post Link to post Share on other sites
Oldskool 6,679 #82 Posted August 21, 2023 I finally had a moment to work on this little guy again. The throttle shaft had alot of play in it so I spun out a bushing for it. I have gas and fire with a jumper. It will start with a squirt of starter fluid then die. When trying to start with just the carb all it does it buck to starter. I was thinking a stuck valve 🤔, but it starts with a shot. I know I'm over looking something, but what 1 Share this post Link to post Share on other sites
Oldskool 6,679 #83 Posted August 21, 2023 I finally had a moment to work on this little guy again. The throttle shaft had alot of play in it so I spun out a bushing for it. I have gas and fire with a jumper. It will start with a squirt of starter fluid then die. When trying to start with just the carb all it does it buck to starter. I was thinking a stuck valve 🤔, but it starts with a shot. I know I'm over looking something, but what Share this post Link to post Share on other sites
Oldskool 6,679 #84 Posted August 21, 2023 I finally had a moment to work on this little guy again. The throttle shaft had alot of play in it so I spun out a bushing for it. I have gas and fire with a jumper. It will start with a squirt of starter fluid then die. When trying to start with just the carb all it does it buck to starter. I was thinking a stuck valve 🤔, but it starts with a shot. I know I'm over looking something, but what Share this post Link to post Share on other sites
Oldskool 6,679 #85 Posted August 21, 2023 I finally had a moment to work on this little guy again. The throttle shaft had alot of play in it so I spun out a bushing for it. I have gas and fire with a jumper. It will start with a squirt of starter fluid then die. When trying to start with just the carb all it does it buck to starter. I was thinking a stuck valve 🤔, but it starts with a shot. I know I'm over looking something, but what Share this post Link to post Share on other sites
953 nut 70,664 #86 Posted August 22, 2023 15 hours ago, Oldskool said: When trying to start with just the carb all it does it buck to starter. Could be the ignition timing is off or you have a condenser that has gone bad, time for an ignition tune-up. 1 Share this post Link to post Share on other sites
Oldskool 6,679 #87 Posted August 22, 2023 6 hours ago, 953 nut said: Could be the ignition timing is off or you have a condenser that has gone bad, time for an ignition tune-up. I never gave much thought to the condenser. It has good fire Share this post Link to post Share on other sites
953 nut 70,664 #88 Posted August 23, 2023 16 hours ago, Oldskool said: I never gave much thought to the condenser. It has good fire Here is some information I saved from a post by @Save Old Iron. If an engine idles well, but runs erratically when revved up, like it hits and misses, pops and backfires, then chances are, it needs a new condenser/capacitor. And always install a condenser/capacitor with the wire facing downward so rain water and/or when washing off engine, water will not enter inside condenser/capacitor, ruining it. With water inside the condenser, this will also allow it to idle well, but cause it to run erratically when revved up. 1 1 Share this post Link to post Share on other sites
ebinmaine 81,289 #89 Posted August 25, 2023 @Oldskool Any luck on this yet? Share this post Link to post Share on other sites
Oldskool 6,679 #90 Posted August 25, 2023 9 hours ago, ebinmaine said: @Oldskool Any luck on this yet? No. Between work and the weather I haven't been back to it yet. 1 Share this post Link to post Share on other sites
