RED-Z06 2,718 #1 Posted April 9, 2023 I know there's a 600 dollar retrofit kit to replaceable tines, but do they still sell the original style where they are like a plate that bolts to the central hub? Share this post Link to post Share on other sites
lynnmor 8,650 #2 Posted April 9, 2023 2 hours ago, RED-Z06 said: I know there's a 600 dollar retrofit kit to replaceable tines, but do they still sell the original style where they are like a plate that bolts to the central hub? Best I can tell it appears that you are out of luck. Toro no longer lists my model number, and when I go to a newer version the tines shown are for one side only and that one is/was $722.94. The Toro parts website is becoming quite a cluster. 1 Share this post Link to post Share on other sites
RED-Z06 2,718 #3 Posted April 9, 2023 Just now, lynnmor said: Best I can tell it appears that you are out of luck. Toro no longer lists my model number, and when I go to a newer version the tines shown are for one side only and that one is/was $722.94. The Toro parts website is becoming quite a cluster. So the retrofit is what im looking at...ouch Share this post Link to post Share on other sites
lynnmor 8,650 #4 Posted April 9, 2023 1 minute ago, RED-Z06 said: So the retrofit is what im looking at...ouch At least the retro has replaceable parts so future maintenance might be much cheaper, if available then. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,017 #5 Posted April 9, 2023 Often wonder if these could be bolted on. I don't have a Wheel Horse tiller to know. This is a distributor in Ontario Canada. https://www.bantasaw.com/catalog/viewproduct.asp?i=&p=8531 1 Share this post Link to post Share on other sites
kpinnc 17,297 #6 Posted April 10, 2023 I used a set of Ford tines for my tiller some years back. Only difference was where the pin hole was in the axle sleeve. So if you're just looking for the individual tine sets, you should have some options out there. Share this post Link to post Share on other sites
RED-Z06 2,718 #7 Posted April 10, 2023 15 minutes ago, kpinnc said: I used a set of Ford tines for my tiller some years back. Only difference was where the pin hole was in the axle sleeve. So if you're just looking for the individual tine sets, you should have some options out there. I need to get my pins out and do some measuring. It looks different than other tillers ive seen Share this post Link to post Share on other sites
