857lover 291 #1 Posted April 4, 2023 hey guys i was wondering if anyone has every done a repower on a d series’s tractor i know it would be expensive but i’m willing to put a little money in to make this work my onan on the tractor does run it’s just a little finicky as i put a carb and intake from a 416 on to it …took a little modification to make it fit but it works half decent but i can’t get the original air cleaner on i did all this because the orginal carb was missing the needle for some reason and i could find one anywhere and i just want the peace of mind of a new engine like one of those twin predators or briggs 3 Share this post Link to post Share on other sites
Pullstart 69,605 #2 Posted April 4, 2023 I’ve seen the predator twins used… but I am guessing someone has got to have a carb to keep yours running. Did you try A-Z Tractor? 3 1 Share this post Link to post Share on other sites
857lover 291 #3 Posted April 4, 2023 Just now, Pullstart said: I’ve seen the predator twins used… but I am guessing someone has got to have a carb to keep yours running. Did you try A-Z Tractor? i live 30 minutes away from lincoln but he dosent have a needle 1 Share this post Link to post Share on other sites
Pullstart 69,605 #4 Posted April 4, 2023 Does he have a carb? 2 Share this post Link to post Share on other sites
857lover 291 #5 Posted April 4, 2023 4 minutes ago, Pullstart said: Does he have a carb? no the last time i was there he didn’t 2 Share this post Link to post Share on other sites
Handy Don 16,242 #6 Posted April 4, 2023 1 hour ago, 857lover said: the orginal carb was missing the needle for some reason and i could find one anywhere Aftermarket carbs are a bit of a gamble (experiences related by members are some good, some not so...) but it may be worth a try in your situation. LOTS less than a repower. I recall that the jets on the P216 and P220 carbs differed to handle the slightly greater displacement and longer valve opening of the latter, along with a couple other differences. 1 1 Share this post Link to post Share on other sites
857lover 291 #7 Posted April 4, 2023 (edited) 11 minutes ago, Handy Don said: Aftermarket carbs are a bit of a gamble (experiences related by members are some good, some not so...) but it may be worth a try in your situation. LOTS less than a repower. I recall that the jets on the P216 and P220 carbs differed to handle the slightly greater displacement and longer valve opening of the latter, along with a couple other differences. yeah i can’t even find a aftermarket carb for the onan bf-ms they are all for a p or g series engine. the carb i have is square Edited April 4, 2023 by 857lover 3 Share this post Link to post Share on other sites
pacer 3,179 #8 Posted April 4, 2023 B43 carb kits are plentiful on the bay and they will have a needle plus a bunch of other stuff --- dozens. Just enter B43 carb kit in search..... But you are right in saying they ARE finiky!!! This one is $16.50 4 Share this post Link to post Share on other sites
Handy Don 16,242 #9 Posted April 4, 2023 11 minutes ago, 857lover said: yeah i can’t even find a aftermarket carb for the onan bf-ms they are all for a p or g series engine. the carb i have is square Ultimately, the key elements of a carb are to fit on the manifold as well as the match to the displacement and air intake velocity at various RPMs to create a suitable fuel mixture over that range. Higher displacement with a smaller bore accelerates the airflow through the carb and can sometimes cause turbulence as well as prevent it from mixing in adequate fuel. 1 1 1 Share this post Link to post Share on other sites
857lover 291 #10 Posted April 4, 2023 do you think this kit would work for my engine ? Share this post Link to post Share on other sites
Pullstart 69,605 #11 Posted April 4, 2023 34 minutes ago, 857lover said: yeah i can’t even find a aftermarket carb for the onan bf-ms they are all for a p or g series engine. the carb i have is square I think you need a turbo for it! That’ll fix it right up! 1 2 Share this post Link to post Share on other sites
857lover 291 #12 Posted April 4, 2023 1 minute ago, Pullstart said: I think you need a turbo for it! That’ll fix it right up! always wanted to do that 😂 it’s on my bucket list ! 2 Share this post Link to post Share on other sites
pacer 3,179 #13 Posted April 4, 2023 2 minutes ago, 857lover said: this kit would work for my engine ? @857lover sure, you do have a B43M dont you? 2 Share this post Link to post Share on other sites
857lover 291 #14 Posted April 4, 2023 2 minutes ago, pacer said: @857lover sure, you do have a B43M dont you? 1 Share this post Link to post Share on other sites
Handy Don 16,242 #15 Posted April 4, 2023 24 minutes ago, pacer said: B43 carb kits are plentiful on the bay and they will have a needle plus a bunch of other stuff --- dozens. Just enter B43 carb kit in search..... But you are right in saying they ARE finiky!!! This one is $16.50 Not a big investment to try it. 1 Share this post Link to post Share on other sites
pacer 3,179 #16 Posted April 4, 2023 Well..... that dont exactly say B43, but from your earlier pic, that looks like it would take the square carb which is whats on the 43's. I had one and became intimate with that dang carb, and your engine sure looks like mine. Some of the 43's had a built in fuel pump on the carb and others - like mine, had a off mount 'pulse' pump - the basic carb is the same tho. 2 Share this post Link to post Share on other sites
857lover 291 #17 Posted April 4, 2023 18 minutes ago, pacer said: Well..... that dont exactly say B43, but from your earlier pic, that looks like it would take the square carb which is whats on the 43's. I had one and became intimate with that dang carb, and your engine sure looks like mine. Some of the 43's had a built in fuel pump on the carb and others - like mine, had a off mount 'pulse' pump - the basic carb is the same tho. i will definitely give it a try 2 Share this post Link to post Share on other sites
TJ5208 1,841 #18 Posted April 5, 2023 1 hour ago, Pullstart said: I think you need a turbo for it! That’ll fix it right up! So who all has a turbo Onan would love to see it and see how it performs. 1 Share this post Link to post Share on other sites
857lover 291 #19 Posted April 9, 2023 On 4/4/2023 at 9:18 PM, TJ Salyers said: So who all has a turbo Onan would love to see it and see how it performs. i now can say me 1 Share this post Link to post Share on other sites
TJ5208 1,841 #20 Posted April 9, 2023 36 minutes ago, 857lover said: i now can say me Yes you can. 1 Share this post Link to post Share on other sites
8ntruck 8,752 #21 Posted April 9, 2023 3 hours ago, 857lover said: i now can say me Pictures? Video? Share this post Link to post Share on other sites
857lover 291 #22 Posted April 9, 2023 Just now, 8ntruck said: Pictures? Video? 1 1 Share this post Link to post Share on other sites
857lover 291 #23 Posted April 9, 2023 (edited) 1 minute ago, 857lover said: it’s still a work in progress onlh had it for one day working out some kinks Edited April 9, 2023 by 857lover 1 Share this post Link to post Share on other sites
TJ5208 1,841 #24 Posted April 9, 2023 Now it's a turbo d160. 1 Share this post Link to post Share on other sites
