Aaron in SC
How much weight can hydro lift, lift
Aaron in SC
I just got a 520h and am wondering how much weight the hydro lift can lift. I have a sleeve hitch attachment sears tiller with its own motor that is pretty heavy and don't want to tear anything up. Just wondering if it can lift this without any problems. I want to use this until I can find a wheel horse tiller attachment for it. Thanks.
Stigian
Hi, I cant help you out with the exact weight your 520-H can lift, but here's a pic of my 518-H happily lifting my very heavy harrow :thumbs2:
Trying to lift it on my 312-8 is normally a 2 handed, foot against the steering wheel kinda act!!! Well not quite but it is a real struggle to lift!..
Enough rambling, here's the pic..
gd.pudge
i have hyd lift on a charger 12 also have a 36"sears tiller with a 6.5 h.p engine on it it will lift it fine.does make the front end lite
kpinnc
A 520-H can carry a 60 inch mower deck, which is around 225 lbs. The hydraulic lift picks it up no problem.
Kevin
TT
As for the capabilities of the rear lift........
The lift cable will break long before the hydraulics run out of power. :thumbs2:
