porkchop 1 #1 Posted July 26, 2009 What other than a broken ring could cause this engine to burn a qt of oil while mowing 2 acres smokes bad. Share this post Link to post Share on other sites
Duff 206 #2 Posted July 26, 2009 What other than a broken ring could cause this engine to burn a qt of oil while mowing 2 acres smokes bad. Worn out valve guides? Duff :thumbs2: Share this post Link to post Share on other sites
MikesRJ 562 #3 Posted July 27, 2009 A leak-down test will give you a better idea of what you're looking at, but either way you're going to be opening the engine soon, or replacing it. Better get to it (or get it looked at if you do not have the means to perform a leak-down test) now than get to it later. Much more expensive later. Share this post Link to post Share on other sites
