Mushrush 18 #1 Posted March 16, 2023 Just bought this 312-8. I'd like to know a little more about it. Can't find a data plate or decal anywhere on it. It looks like they touched it up with rattle can red. It came with a plow but is missing parts to privet the blade. Can't find them anywhere. Lower index rod? It starts and runs real good. It plows ok, I wonder if it'll plow better if I can pivot the blade. Haven't tried the mower deck yet. It's the smaller one with the rear discharge. Any help you can give a fella would be greatly appreciated 12 Share this post Link to post Share on other sites
ebinmaine 80,653 #2 Posted March 16, 2023 You'll find that to be an excellent worker for you. Good catch. The plow index rod can be made from 2 heim joints and a piece of rod. We just did one for my 1975 C160 Automatic Restoration. Highly recommend it. The heim joint takes all the slop and looseness out of the possibilities and makes the plow easier to pivot. 2 2 Share this post Link to post Share on other sites
Blasterdad 3,168 #3 Posted March 16, 2023 (edited) Look for ID sticker under the seat, if it's painted over lightly rub some brake fluid or nail polish remover over it & see if you can read it. Edited March 16, 2023 by Blasterdad 2 1 Share this post Link to post Share on other sites
Pullstart 71,216 #5 Posted March 16, 2023 And great machine! Check out this Baseline checklist thread if you are looking for any maintenance advice. It would be a great idea to check the transmission fluid condition to tell if it’s been left outside for any extended periods. If it’s milky or gross, a thorough flush is in order! 5 1 Share this post Link to post Share on other sites
Racinbob 13,135 #6 Posted March 16, 2023 It looks to me that you have the parts to index the plow. What I don't see is the rear axle bracket to mount it and the lift arm. 1 Share this post Link to post Share on other sites
Blasterdad 3,168 #7 Posted March 16, 2023 Can you post a pic of the PTO side of you ? Might be the camera angle but it looks like the deck belt is on wrong (twist in it). If it is the blades will spin backwards. 1 Share this post Link to post Share on other sites
Pullstart 71,216 #8 Posted March 16, 2023 15 minutes ago, Pullstart said: And great machine! Check out this Baseline checklist thread if you are looking for any maintenance advice. It would be a great idea to check the transmission fluid condition to tell if it’s been left outside for any extended periods. If it’s milky or gross, a thorough flush is in order! @wildbill69 and @Keith Plett be sure to check out that link as well, for anything we might have missed in your posts! 3 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,484 #9 Posted March 16, 2023 Some had the tractor data decal under the front of the seat and later moved to under the left side of the seat both on the rear fender pan. Post the numbers off the engine data plate including the serial number - sometimes we can ID the tractor model from them. Maroon decals like you have 1985-1989 4 Share this post Link to post Share on other sites
953 nut 69,164 #10 Posted March 16, 2023 (edited) 312-8 will get the job done for sure. Since it has a Magnum engine it would be a 1987 or newer up to 1990 when the black decals were introduced on the hood. Edited March 17, 2023 by 953 nut 1 Share this post Link to post Share on other sites
Brockport Bill 2,470 #11 Posted March 16, 2023 i have had that 312-8 tractor model bought new since 1989 --- over 2,000 hours -- awesome machine - here's photo of my then 8 yr old son plowing with it first winter in 1989, plow photo of recently reconditioned plow blade, and recent photo 33 years later of tractor and plow, and our 37 inch side discharge mower we restored after 3 decades of use. I have also used with our tiller for garden and lawn plus pulled a roller to install our lawn -- machine does everything you will ask! 1 4 Share this post Link to post Share on other sites
Mushrush 18 #12 Posted March 16, 2023 (edited) 2 hours ago, ebinmaine said: You'll find that to be an excellent worker for you. Good catch. The plow index rod can be made from 2 heim joints and a piece of rod. We just did one for my 1975 C160 Automatic Restoration. Highly recommend it. The heim joint takes all the slop and looseness out of the possibilities and makes the plow easier to pivot. How long should the rod be? I'm guessing around 36 inches. And I'd probably have to tap the rod ends to fit the heim joints? Edited March 16, 2023 by Mushrush Misspelled 2 Share this post Link to post Share on other sites
Blasterdad 3,168 #13 Posted March 16, 2023 28 minutes ago, Mushrush said: How long should the rod be? I'm guessing around 36 inches. And I'd probably have to tap the rod ends to fit the heim joints? You can use a piece of thread-all, put a joint on one end of the rod & bolt it to the front of the plow. Angle plow all the way to the left. Bolt the other joint to the bottom of the control lever. Move the control lever so it's back as far as it can go without hitting the footrest or interfereing with the brake pedal. This will be the length to cut the rod, allowowing about an inch of thread to go into the joint. 1 Share this post Link to post Share on other sites
23 Reo 242 #14 Posted March 16, 2023 The 12hp 8 speeds are great. My C-125 runs a 48" deck with ease. You'll be happy. 2 Share this post Link to post Share on other sites
Mushrush 18 #15 Posted March 16, 2023 6 hours ago, Blasterdad said: Look for ID sticker under the seat, if it's painted over lightly rub some brake fluid or nail polish remover over it & see if you can read it. I think I found it. Exactly where you said it was. Luckily, he taped over it when he repainted it 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,484 #16 Posted March 17, 2023 2 pages of files on the 1988 model 21-12K805 https://www.wheelhorseforum.com/search/?&q=21-12k805&type=downloads_file&page=2&search_and_or=or&sortby=relevancy 4 Share this post Link to post Share on other sites
CCW 1,519 #17 Posted March 17, 2023 I have the same tractor. It does everything and more. Share this post Link to post Share on other sites
Gary S Minnesota 62 #18 Posted March 17, 2023 I have had mine for 26 years. As was said before, wonderful machine. 1500 plus hours on her. Blows snow every winter and mows grass every summer. Just keeps running like the day I brought it home. Keep the oil clean ( I change Spring and Fall ). and be sure you keep all of the grease fittings well lubed. You’ll be very happy with it! 2 Share this post Link to post Share on other sites
ohiofarmer 3,475 #19 Posted March 18, 2023 (edited) I picked up a nice 314 -8 and the only change is a bigger front tire.that makes it a 400 series in all but the name i was told. [i am no expert on that] I can say from the perspective of the 300 and 400 series-- Take off the belt cover and make absolutely sure that the plastic bushing that goes around the belt tightening idler pulley rod is in good shape. if it wears through, it is steel on steel wearing an oblong hole in the support frame. Mine was worn so bad that it took a flanged oilite bushing and a lot of work to replace it. Maybe the regular members get tired of me repeating this stuff, but newer members need to know about it. Probably the most under engineered part on the machine that is unfortunately hidden from sight. The fact that you have a manual transmission gives you a beast of a machine. Enjoy. Edited March 18, 2023 by ohiofarmer Share this post Link to post Share on other sites
JCM 11,415 #20 Posted March 18, 2023 One of the best that ever came out of South Bend Indiana IMHO. Simple and super reliable. Good luck with it. 1 1 Share this post Link to post Share on other sites
