plowmaster 0 #1 Posted July 25, 2009 is there anything i can cross reference to find the models that had the same pulley as an A-100? the only reason i would like to get it running is i have a great running larger motor with a super quiet rebuilt deck. i see alot of models with the same build as the a, so it seems only fitting i should be able to find one that fits. id love to get this mower going so i dont have to move mowers between the farm, shop, and house. thanks. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #2 Posted July 25, 2009 The pulley is P/N 105070 and was used only on the 1976/77 A-90 & A-100 models. As you've probably guessed, it is no longer available new from Toro and there is no supercession to a different part number. Newer models used either a tapered PTO clutch arrangement or an electro-magnetic PTO clutch mounted directly to the crankshaft - both of which could possibly be adapted to your mower, but not very easily. Here's my suggestion: You can either try to adapt a stack pulley from a different brand of mower or you might be able to buy individual pulleys of the correct sizes and have them welded to a common hub. Share this post Link to post Share on other sites
plowmaster 0 #3 Posted July 26, 2009 looks like im going to have to weld them up, thanks for the help terry! Share this post Link to post Share on other sites
