BrianStasC-101 5 #1 Posted March 14, 2023 Hello all this is my first post and my first tractor beginning the wheel horse journey(c-101). I was recently tinkering with my head and tail lights (removing the junk LED lights someone installed for headlights) and see that there only appears to be a positive wire running to both head and tail lights and I was wondering where they receive ground as the tail lights only work when the fender is tight and the headlights flicker as I open and close the hood if they are turned on and they become steady on once the hood is latched. 1 Share this post Link to post Share on other sites
ebinmaine 77,806 #2 Posted March 14, 2023 The ground is expected to come from the chassis itself and quite frankly, does not do the best job at that. I've rebuilt 8 or 10 full chassis harnesses over the last few years and I've gotten in the habit of running a separate ground to EVERY component. If I change over to LEDs I use the ground wire coming from the bulbs themselves or if I stay with a stock type bulb I run aground wire right to the base of the socket of the lamp. There should be large ground wires of 6 gauge or thicker going from battery ground to both frame AND engine. The gauge sizes of the rest of the ground wires are determined by the component. 4 1 Share this post Link to post Share on other sites
Achto 31,310 #4 Posted March 14, 2023 (edited) Like Eric, I also run a separate ground to the lights on my tractors. Edited March 14, 2023 by Achto 2 Share this post Link to post Share on other sites
kpinnc 17,499 #5 Posted March 15, 2023 On 3/14/2023 at 9:47 AM, ebinmaine said: I've rebuilt 8 or 10 full chassis harnesses over the last few years and I've gotten in the habit of running a separate ground to EVERY component. Pure wisdom! A ground jumper between the frame and hood/ fender is just plain good practice. It is all benefits with no risk. 1 1 Share this post Link to post Share on other sites
