plowmaster 0 #1 Posted July 24, 2009 whats the dry weight of a charger 12 w/o attachments? how about the weight of a 42" mower deck? is there anyplace to look up the weight of all wh tractors/ thanks Share this post Link to post Share on other sites
gd.pudge 2 #2 Posted July 24, 2009 look at tractordata.com that might tell ya Share this post Link to post Share on other sites
CasualObserver 3,410 #3 Posted July 24, 2009 I've got a spec sheet for a 1968 Charger 12, which is essentially the same. Approx 650 lbs on the tractor. Don't know about the deck... its probably in the 75-100 lbs range. Hope that helps. I don't know of anywhere to look up all the weights in one place. Share this post Link to post Share on other sites
plowmaster 0 #4 Posted July 24, 2009 look at tractordata.com that might tell ya nope, none that i can find. if found tractor data to be wrongo on too many occasions to trust fully anyway. really, once is enough. Share this post Link to post Share on other sites
plowmaster 0 #5 Posted July 24, 2009 I've got a spec sheet for a 1968 Charger 12, which is essentially the same. Approx 650 lbs on the tractor. Don't know about the deck... its probably in the 75-100 lbs range. Hope that helps. I don't know of anywhere to look up all the weights in one place. thank you, that helps. i think i read somewhere that a 60" deck is upwards of 250, sound right? i thought it sounded a bit on the heavy side, but i dunno, ive never seen one in real life. Share this post Link to post Share on other sites
