Wheel Horse312-8 2 #1 Posted February 28, 2023 Hello, I have a snow plow attachment for my 417xt tractor. When the plow is attached to the frame of the tractor, it is only able to be lifted about 3” because the plow frame hits up to the bottom of the tractor. I don’t see any way around this and I’m hoping there is some work around to allow the plow blade to get a higher lift thanks 1 Share this post Link to post Share on other sites
Wayne0 1,648 #2 Posted February 28, 2023 I gotta' say, on my Workhorse, I can only get the blade about 2" off the ground. If it hits the frame, higher is not an option. 3 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,510 #3 Posted February 28, 2023 Which one do you have? First two require Conversion Kit 106-8256 and Rear Attach-A-Matic Hitch 106-5694 or 107-8490 This one requires Rear Attach-A-Matic Hitch 106-5694 or 107-8490 3 Share this post Link to post Share on other sites
953 nut 69,810 #4 Posted February 28, 2023 10 hours ago, Wheel Horse312-8 said: able to be lifted about 3” because the plow frame hits up to the bottom of the tractor That is about all the lift you can expect. Once the plow frame hits the front axle that is about it. Share this post Link to post Share on other sites
Ed Kennell 47,595 #5 Posted February 28, 2023 A couple options are taller front tires and spacer blocks to lower the rear axle attachment point. 2 Share this post Link to post Share on other sites
SylvanLakeWH 32,697 #6 Posted February 28, 2023 1 hour ago, Ed Kennell said: A couple options are taller front tires and spacer blocks to lower the rear axle attachment point. But if you mow with it as well the taller tires may impact deck angle / cut quality... 1 Share this post Link to post Share on other sites
Wheel Horse312-8 2 #7 Posted February 28, 2023 15 hours ago, gwest_ca said: Which one do you have? First two require Conversion Kit 106-8256 and Rear Attach-A-Matic Hitch 106-5694 or 107-8490 This one requires Rear Attach-A-Matic Hitch 106-5694 or 107-8490 Thanks, I downloaded the file, I have the full frame plow mount, I'll take a look today and see if removing the pully box will give me a few more inches. Share this post Link to post Share on other sites
Wheel Horse312-8 2 #8 Posted February 28, 2023 35 minutes ago, SylvanLakeWH said: But if you mow with it as well the taller tires may impact deck angle / cut quality... Thanks, I considered taller tires, but like you mentioned that would require perhaps resetting mower deck adjustments, I might try taking off the pully box to see if that gives me a few more inches. 1 Share this post Link to post Share on other sites
