rick 258 #1 Posted February 26, 2023 I have a complete Wheel Horse tiller that works on a '97 314-8. Will the tiller fit my '75 C100? Thanks, Rick 2 Share this post Link to post Share on other sites
ebinmaine 74,635 #2 Posted February 26, 2023 If the C100 is an 8 speed like the 314 it should bolt right up. 1 Share this post Link to post Share on other sites
clueless 3,325 #3 Posted February 26, 2023 2 hours ago, ebinmaine said: If the C100 is an 8 speed like the 314 it should bolt right up. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,752 #4 Posted February 27, 2023 The rear rock shaft part of the lift is a different length because the C-100 has no rear fuel tank. Here is the tiller available in 1975 3 Share this post Link to post Share on other sites
Racinbob 12,244 #5 Posted February 27, 2023 The tiller itself is the same but there are slight differences in the lift. The 75 didn't use a rockshaft under the seat where the 76+ did. You can easily duplicate per the parts list. Maybe add a rock shaft which would be nice but I'm not sure one was made for a 75. I have one for a 76-77 but those years the seat was fixed and didn't tilt back like the 75's. 2 Share this post Link to post Share on other sites
rick 258 #6 Posted February 27, 2023 Thanks for all the help, guys. I may go forward with this, or not since I have 2 tractors the tiller will fit without fidgeting around. Has anyone replaced the tiller tines without trading a daughter to Toro for the OEM tines? Share this post Link to post Share on other sites
