ML3 2,504 #1 Posted February 23, 2023 Have 84 C105 8sp. Need to replace all 4 tires. They are original & about worn out, not to mention hard. Not sure if I should stay with the OEM turf style or not?? I do absolutely no mowing with tractor. I do use it to push snow on a flat but brand new cement driveway. Tire chains are absolutely out of the question! I have about 95lbs of weight on the hitch which really helps. Also have snowblower that I haven't tried yet & don't know if I'll ever use it? Tractor is used more for pushing snow, dirt, & hauling trailer around yard. Thinking of going to agriculture type tires for better grip but I've heard that they aren't as good for the snow. Suggestions???? 1 Share this post Link to post Share on other sites
rjg854 13,342 #2 Posted February 23, 2023 Rubber tire chains, instead of the steel ones 1 Share this post Link to post Share on other sites
ebinmaine 80,653 #3 Posted February 23, 2023 @Sparky What're those neat rear zig zag sneakers your machine is using? 10 minutes ago, rjg854 said: Rubber tire chains, instead of the steel ones Agreed. Also FLUID FILLED TIRES. More weight is your friend. Find Rimguard fluid if you can it reasonably. For the front tires perhaps use some snowblower type? Share this post Link to post Share on other sites
Sparky-(Admin) 26,324 #4 Posted February 23, 2023 Just now, ebinmaine said: @Sparky What're those neat rear zig zag sneakers your machine is using? Agreed. Also FLUID FILLED TIRES. More weight is your friend. Find Rimguard fluid if you can it reasonably. For the front tires perhaps use some snowblower type? I swear by these! I have Carlisle All-Trails on a couple machines. My plow machine has weights and NO CHAINS and it does great 3 Share this post Link to post Share on other sites
Blasterdad 3,168 #5 Posted February 23, 2023 Carlisle HD Field Trax 1 Share this post Link to post Share on other sites
pfrederi 21,145 #6 Posted February 23, 2023 Pair of those would about double the value of any of my WHs... 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,468 #7 Posted February 23, 2023 same tractor same situation with flat new concrete drives (3)... no weight no chains. done it for years... carlisle turfs. 2 Share this post Link to post Share on other sites
ML3 2,504 #8 Posted February 23, 2023 I really like the all trail type tread. I really don't wanna mess with even the rubber chains. Thanks. I'm gonna look into find them. Not concerned about price, I need results 2 Share this post Link to post Share on other sites
Pullstart 71,216 #9 Posted February 23, 2023 1 hour ago, Blasterdad said: Share this post Link to post Share on other sites
Blasterdad 3,168 #10 Posted February 23, 2023 3 hours ago, Pullstart said: Been waiting to get them mounted & put on one of the 's to post in your thread. 1 1 Share this post Link to post Share on other sites
Tonytoro416 1,381 #11 Posted February 23, 2023 The versa turfs in the first picture are super awesome Share this post Link to post Share on other sites
Tonytoro416 1,381 #12 Posted February 23, 2023 7 hours ago, mjl111070@yahoo.com said: I really like the all trail type tread. I really don't wanna mess with even the rubber chains. Thanks. I'm gonna look into find them. Not concerned about price, I need results Carlisle versa turf Share this post Link to post Share on other sites
rick 316 #13 Posted February 24, 2023 @Tonytoro416 What tire pressure do you use for those Versa Turf tires? I looked at them on the Carlisle site and they suggest 50 psi! Share this post Link to post Share on other sites
Tonytoro416 1,381 #14 Posted February 24, 2023 I have 30 in mine 1 Share this post Link to post Share on other sites
Tonytoro416 1,381 #15 Posted February 24, 2023 I’m guessing because they are radial and the have some flex. 1 Share this post Link to post Share on other sites
ebinmaine 80,653 #16 Posted February 24, 2023 3 minutes ago, Tonytoro416 said: I’m guessing because they are radial and the have some flex. Seems like a reasonable explanation. What's the intended original application of those tires? Higher load range than a standard garden tractor tire? Share this post Link to post Share on other sites
Tonytoro416 1,381 #17 Posted February 24, 2023 I’m not sure I know they are a option on brand new subcompact tractors of the green variation 1 Share this post Link to post Share on other sites
Blasterdad 3,168 #18 Posted February 24, 2023 7 minutes ago, ebinmaine said: Seems like a reasonable explanation. What's the intended original application of those tires? Higher load range than a standard garden tractor tire? Lawn & garden 1 Share this post Link to post Share on other sites
