gris71 12 #1 Posted February 18, 2023 I have a wheel horse 312a I think the clutch plates are bad in the pto off the side of the motor it starts to run the mower deck belt then stops it is getting hot I think the clutch plates are bad. is there a parts breakdown for the clutch or dose anyone know the part number thanks for your help Share this post Link to post Share on other sites
Sparky-(Admin) 26,206 #2 Posted February 18, 2023 Almost sounds like you have some slippage. Is the clutch adjusted so when it’s engaged the bell is tight up against it? Take a scroll thru the manuals section, I’m sure we have yours in here. https://www.wheelhorseforum.com/files/category/31-1985-1990/ 1 Share this post Link to post Share on other sites
gris71 12 #3 Posted February 18, 2023 I dont know how to adjust the clutch Share this post Link to post Share on other sites
Sparky-(Admin) 26,206 #4 Posted February 18, 2023 1 hour ago, gris71 said: I dont know how to adjust the clutch You add tension by turning this trunion, closer to the PTO handle, a little bit at a time. 2 1 1 Share this post Link to post Share on other sites
peter lena 10,013 #5 Posted February 19, 2023 @gris71 question , how easily can you move that drive belt by hand? tractor shut off , key in pocket ,collective attachment drag , from related bearings , grass build up under deck , as well as clutch adjustment can add up to very heavy belt drag . the easier it all spins up by hand , should be easy for the drive belt to move it , pete 1 Share this post Link to post Share on other sites
wallfish 20,504 #6 Posted February 19, 2023 Also inspect this area and the bracket. There should be a pin holding it on which is common to fail after 30-40 years. If it's not attached correctly you can't adjust enough. Post a pic of yours so we can see it 3 1 Share this post Link to post Share on other sites
